- Clicking when in 4WD when turning
- Banging and snatching of the steering wheel
- Loss of 4wd
CV joint information
Identifying type
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts aftermarket and the other is nearly impossible to source.
- Type 1: 6 balls, 26 external splines and 19 internal splines. - BigJimny Store NTN 75LAC CT9U)
- Type 2: 8 balls, 26 external splines and 29 internal splines. - BigJimny Store (possibly marked NTN EBJ82 although NTN call it an 8-Ball CV)
Model | Balls | Inner Splines | Outer Splines | Outer Case Dia | Inner Case Dia | Shaft Dia | Type |
NTN BJ75LAC | 6 | 19 | 26 | 91.6mm | 72.6mm | 19.0mm | Type 1 |
NTN EBJ82 | 8 | 29 | 26 | 91.6mm | 72.6mm | 21.2mm | Type 2 |
CV Joint compatibility
Note: check the specific joint for your vehicle before ordering.
Country of Manufacture | Engine | VIN Number | CV Type |
Japan (JSA) | G13B | ALL | Type 1 |
Spain (VSE) | G13B | ALL | Type 2 |
All | M13A | up to 00186627 | Type 1 |
All | M13A | from 00186627 | Type 2 |
NTN 75LAC CV Joint
NTN EBJ82 Style CV Joint
Note these pictures are of a 6-ball copy (the real thing is an 8 ball CV but is not available as a standalone CV, it comes with the full drive shaft)
Changing the CV joint
Required parts
Part name | Quantity | Suzuki P.N. | Aftermarket replacements | Comments |
Constant velocity joint | 1 piece | Type 1: 44101-81A00 (right) 44102-81A00 (left) Type 2: 44101-84A00 (right) 44102-84A00 (left) |
Type 1: Various Type 2: 1. Herth+Buss Jakoparts J2828040 2. NKN N-5979-2HO |
Original Suzuki CV joints are galactically expensive because they always come pre-assembled together with a halfshaft. The left and right Suzuki CV joint of the same type are identical, only the halfshafts are different. See the chapter about CV joint types for more info about different CV joint types. |
Halfshaft oil seal | 1 piece | 09283-26016 | Any seal with dimensions: "26 x 38 x 9" (best fit); "26 x 38 x 8" (good fit); "26 x 38 x 7" (okay fit); |
Changing this part is not strictly needed in this procedure, especially if it is found to be in good condition after all the dismantling. However, since it is so cheap compared to the CV joint, and since you will need it sooner or later anyway, it is recommended to preventively obtain one now. Original Suzuki seal is recommended, because it has special "double lip" construction. Aftermarket seals usually do not have double lips. Also, most of them are shallower (8 mm or even 7 mm depth compared to Suzuki's 9 mm). While a shallower seal is not a critical mismatch, is is always better to avoid them, because shallower seals have smaller sealing / contact area. |
Steering knuckle swivel seal | 1 piece | 45120-81A04 | Febest SZOS-001 | Might not be needed if the current one is not worn out. Its condition is easy to check just by thoroughly looking under the vehicle. Check if the seal's lip is torn, cracked, jammed, kinked, etc. The current P.N. is the 4th (best quality) revision by Suzuki. There used to be older revisions (ending with 81A01, 81A02 and 81A03). Buy an older revision only if it is on a good discount! All those revisions are mutually fully compatible. Buy the Febest replacement only if you can't obtain any Suzuki's original seal. |
Differential oil | 1.1 - 1.65 litre | Who cares | See the wiki article: "Forecourt" |
Not strictly needed (if you jack up only one side of the car, no oil will leak from the axle). However, it is a good idea to change it if the schedule for its replacement is due anyway. |
Heavy-duty nuclear-proof grease | A handful or so | ? | Divinol Fett Top 2003 (23980); |
This is perhaps the most important part! A super-durable water-and-mud-and-everything-else resistant grease is essential for the steering knuckle assembly and for the king pin bearings, to protect from grit, water and mud, which will certainly enter the steering knuckle (one of Jimny's main weaknesses). Forum user Bosanek has had excellent experience with the stated Divinol 23980 grease. This grease is truly wicked - fluorescent green, super thick, very sticky and gooey, like a slime from another galaxy. After a year of hard use, the steering knuckles were opened and it was like a mass grave inside, but this Divinol grease repelled all the grit and sh*t away from the king pin bearings, still keeping them fully and cleanly greased! On the other hand, this Divinol 23980 grease might not be suitable for use in a CV joint (just a presumption because it is very thick and "gooey" - somebody has yet to try it in a CV joint). See the next item for a field-proven CV joint grease. Others are welcome to add their own recommendations to the list! |
Heavy-duty CV joint grease | A handful or so | ? | Abro LG-990 (here are more detailed specifications); |
This is also an extremely important part! A heavy-duty water-and-mud-and-everything-else resistant grease is essential to keep your CV joint protected from grit, water and mud, which will certainly enter the steering knuckle (one of Jimny's main weaknesses). However, a CV joint grease also has to have proper greasing viscosity and consistency (e.g. non-liquifying) properties even under heavy load, high temperatures and high velocities. Forum user Bosanek has had very good experience with the stated Abro LG-990 fully synthetic lithium grease when used in a CV joint. It is not nearly as tough as the wicked Divinol 23980 grease, but on the other hand, it is a "safe bet" to keep the sensitive CV joint properly greased in all operating conditions. Others are welcome to add their own recommendations to the list! |
A calendar with pictures of (half)naked women | 12 pictures / months | Who cares | Claudia Schiffer; Ana Kournikova; Monica Bellucci; Salma Hayek; Bridgitte Bardot; |
An essential part of pleasant working experience in most mechanical garages; It is recommended to flip over calendar's pages / months one by one as you progress trough each step in this guide; |
Required tools
- Assorted screwdrivers
- Circlip pliers (external)
- A ball joint splitter
- 1" imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
Re-assembly
- You may wish to change the king pin bearings and oil seals at this point if you wish.
- Again the BigJimny shop sells suitable sealant.
Page last edited on 23/03/2018 by user Bosanek
