Front fog lamps
Revision as of 08:16, 17 October 2017 by Bosanek (talk | contribs) (Added info that the required wiring might already be present in the vehicle from the factory)
If your vehicle already has front fog lamps (in the front bumper) installed from the factory, you don't need to read this article. Enjoy life.
If you don't have factory-fitted front fog lamps, you might consider buying a pair from a local vehicle junkyard (taken from a dead Jimny).
Required parts
  1. A pair of fog lamps
  2. A pair of mounting brackets
  3. A rectangular button / switch for the driver's console
  4. Possibly the wiring (preferably original cables with connectors etc.) - your vehicle might already have the required wiring
  5. Possibly some more electrics like a relay, a fuse etc.) [not yet investigated]
Note Icon.pngYou will have to cut out plastic blanks in the fog lamp openings in the front bumper. That operation is irreversible. You could glue the blanks back if you abandon the project, but it will hardly look virgin again. Therefore, it is recommended to obtain all the required parts (especially the electrics), and test-wire everything first before you finally cut the bumper and mount the lamps.
Compatibility
Lamps and brackets
  • It appears that the fog lamps are the same for any Jimny revision (1998-2012 at least).
  • However, the mounting brackets are bumper-specific (there have been three bumper revisions so far).
  • See wiki article "Front bumper issues" for some details on bumper revisions.
Wiring
  • The wiring also appears to be the same for all vehicle revisions.
  • Regarding the wiring, refer to a corresponding wiring diagram manual for your vehicle revision (and for donor's vehicle revision if needed).
  • It might easily be possible that the required wiring is already present in the vehicle (there are some reports that Suzuki installed the wiring for the front fog lights in every Jimny).
  • Therefore, you should first check for the presence of the wires and connectors somewhere behind the front inner wheel arch liners, and inside the console in the cabin.
Console button / switch
  • The console switch appears to be the same in pre-2006 Jimnys (with older console version), and in post-2005 Jimnys (with newer console version), but it has not been confirmed if they are identical.
  • The switch is located next to rear fog light switch in a three-switch console cluster.
  • The cluster is located to the left of the steering wheel (for LHD vehicles) or to the right of the steering wheel (for RHD vehicles).
  • The switch is a "permanent press-in" type - after you press it, it stays pressed in until pressed again. The switch also contains a small light indicator which is lit when the switch is pressed in.
Page last edited on 17/10/2017 by user Bosanek
