Revision as of 18:41, 3 June 2016 by Leftcase (talk | contribs) (Created page with " == A guide to changing the clutch. == It is inevitable that at some point you will have to face changing the clutch. It dips in and out of the mud on a regular basis as the...")
Clutch replacement
No special tools are required, but a good toolkit is needed. You will need extension bars for a socket set as some of the bolts are well hidden and difficult to access. A breaker bar is also needed as some bolts are very tight.
To remove the gearbox lever you have to remove the centre console. This is held on by four screws on the side at the front and back.
