Axle
| Item | Torque Nm | Torque lb-ft |
| Radius Arm bolts (Axle) | 27 Nm | 19.5 lb-ft |
| Radius Arm bolts (Chassis) | 50 Nm | 36.5 lb-ft |
Differential
| Diff Drain Plug | 27 Nm | 19.5 lb-ft |
| Diff Filler Plug | 50 Nm | 36.5 lb-ft |
| Prop Shaft Flange Bolts | 50 Nm | 36.5 lb-ft |
| Bevel Gear Bolts | 85 Nm | 61.5 lb-ft |
| Bearing Cap Bolts (front) | 50 Nm | 36.5 lb-ft |
| Bearing Cap Bolts (rear) | 85 Nm | 61.5 lb-ft |
| Lock Plate Bolts | 11.5 Nm | 8.5 lb-ft |
| Front and Rear carrier bolts | 23 Nm | 17 lb-ft |
| Gear Thrust Bolt (front) | 1.5 Nm | 0.1 lb-ft |
| Gear Thrust Bolt (rear) | 85 Nm | 61.5 lb-ft |
Front Hub
| Wheel Nuts | 95 Nm | 69 lb-ft |
| Tie-Rod End Nut | 43 Nm | 31.5 lb-ft |
| Kingpin Bolt | 25 Nm | 18.0 lb-ft |
| Locking Hub Bolts | 48 Nm | 35 lb-ft |
| Swivel Seal Bolts | 10 Nm | 7.5 lb-ft |
| Brake Carrier Bolts | 85 Nm | 61.5 lb-ft |
| Wheel Bearing Lock Nut | 220 Nm | 160 lb-ft |
| Drop-Link/Stabilizer Link ball nut | 50 Nm | 36.5 lb-ft |
| Brake Caliper Slider Bolt | 22 Nm | 16 lb-ft |
| Front Brake Flexi Hose bolt | 23 Nm | 17 lb-ft |
