Jump to navigation
Jump to search
Headlights
| Application | Bulb Fitting |
| Dipped and Main Beam | H4 (472) |
| Side/Parking Lamp | W5W (501) |
| Front Fog Lamp | H3 (453) |
Fitting
Side/Parking Lamp
- Open the bonnet
- The side lamp bulb holder is located at the outer edge of the headlight assembly
- Twist the bulb holder one quarter turn anti-clockwise to remove. If this is difficult, you may find it easier to leave the cable connected as this will give you more purchase on the bulb holder.
- Remove the bulb holder from the assembly and change the bulb.
Headlights
- Open the bonnet
- Remove the socket and the rubber cover
- Unhook the bulb holding spring and replace the bulb
Front Clearance/Turn Signal/Side Turn Signal/ Rear combi/ Number Plate Light
- To remove, simply pull out or push in the bulb.
