Revision as of 07:01, 27 January 2017 by Mlines (talk | contribs) (Created page with "== Changing the Rear Engine Mount == === Tools === {{tools|<ul><li> Standard metric sockets and spanners</li><li>Assorted screwdrivers</li><li>Circlip pliers (External)</l...")
Rear engine mount change
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Before you read the guide below, you may wish to view the video.
This shows the changing of the Kingpin Bearings on a Jimny fitted with ABS so you will see me remove the sensor etc.
The rest of the guide below shows the same task in a series of steps for clarity.
