Gearbox R72 rebuild
Revision as of 12:40, 21 January 2017 by Sheepish (talk | contribs) (→‎Tools)
Rebuild
  • Range of impact sockets used to press in bearings
  • 2 large flat head screw drivers
  • a 2 leg gear puller and/or hydraulic press
  • bearing seperator
  • torque wrench(s) to cover 23-90Nm
  • circlip pliers for 25mm circlips
  • copper or plastic mallet
  • sturdy metal tube of approx 25mm internal diameter, at least 130mm long; but see text for alternatives
Ideally you'll want a copy of the correct service manual. This gearbox is covered under supplementary service manual 99501-81A20-01E. You might get lucky with Google!
Gearbox Removal
Drain Plug
Dismantling
Cover removal
Locating bolts
Output shaft
Output shaft
Looking down on to what is the input shaft, you should be left with the a synchroniser ring (brass colour), under this is a round, lose clip, and in the centre a needle roller bearing. It's worth lifting these out now and keeping safely, in the correct order with your output shaft. They'll only fall out and disappear later when you pull out the input shaft.
Output shaft
Something about removing the mid case here.
Remove the reverse gear. Be careful here, the lever plate (red arrow), connects to one of the shift rods (yellow arrow). If you lift the shift rod it will probably pop off a synchro sleeve on the input shaft, and syncho keys will fall on the floor, and you will be sad.
Reverse lever
Below is a sad syncho sleeve with syncho keys no where to be seen. Don't let the sleeve lift as much as this. You have been warned, etc.
Reverse lever
Next remove the 5th gear shift inverse lever at the base of the shift rods. Just two bolts and lift it out.
At this stage you can release the large circlip at the base of the input shaft and lift away both the input and counter shafts plus the shift rods.
Input and counter shafts
Bearing Replacement
I jumped the gun a bit and got going before dismantling everything. This is the top of the counter shaft. Fairly obvious what is wrong here. In fact this is the only bearing that appeared sub-optimal in my box.
Counter shaft
So I removed it with a hydraulic puller and bearing splitter. None of the bearings took much effort to remove. I'd be confident this could be done with a manual puller.
Hydraulic puller and bearing splitter
Bearing removal is trickier when the bearing is at the bottom of a shaft. You could possibly have tapped this off from behind. On the output shaft there are bearings either side of the gear and the whole lot needs pulling off. I did them one component at a time using a bearing splitter and a hydraulic press.
Output shaft
This isn't the output shaft, but you get the idea.
Bearing Splitter
A better idea of what you are up against with the output shaft here. None of this was hard to pull off (remember it's the bearing shown removed, plus the gear, plus the bearing below the gear with integral circlip) with the splitter and press. Note the blind circlip. There's a couple of these about but actually they weren't much of a problem. Lean on either side with 2 big flathead screwdrivers and they ping off. Sometimes they even remain in sight.
Output shaft
The problem comes when you want to push bearings back onto the shaft. Bearings at the top of shafts are easy if you have a range of impact sockets to act as suitable size presses. But my sockets aren't deep enough for output shafts. You could tap the bearings on with a brass rod and a hammer. If you do this it will be very east to slip off the center race. Put the old bearing on top of the new one and drive on that to protect it. Luckily I know a man with a lathe who drilled a 25mm hole in some 40mm bar.
Man with lathe
I don't know what a machine shop would charge to do this but it made driving the bearings back on very easy. Both bearings and the gear drive on in one action with a press.
Pressing bearings onto output shaft
Oil Seal Replacement
Next job is the oil seals. One of these oil seal removal tools will do the job. Be *very* careful not to score the casting with one of these. Err on the side of caution. There are two oil seals to remove where the input shaft passes through the bellhousing.
Tap new seals into place using a suitable sized drift. Impact sockets are good for this. The first seal needs to go in with the solid face down. Ideally you will have a solid disk to press it in with because you only have the open (U cross-section) of the seal to press on. I was lucky, a 30mm impact socket used upside down did the trick (see picture below). The seal lip of this seal should have grease on it. The genuine Suzuki seals come ready greased.
Pressing first input shaft seal
Here is the first seal in place.
Input shaft seal #1
And the second seal.
Input shaft seal #2
There is also the output shaft seal to replace in the same way in the rear case.
Reassembly
Is the reverse of disassembly, obviously. Nothing tricky here. A few points to note.
The fifth gear shift inverse lever needs threadlock on its bolts. Torque to 23Nm.
Input shaft seal #2
The gear shift locating springs and ball bearings are greased and replaced. The bolts need threadlock (wipe any grease off the case threads), and are torqued to 13Nm (every other bolt on the gearbox is 23Nm)
Gear shift locating springs and balls #2
The reverse gear shaft needs to be positioned such that the bolt that secures it from outside of the centre case will thread into it. There is a small ridge in the casting to line up, but trial fit the centre case and make sure this is exactly right.
Reverse gear shaft alignment
Before the final fit of the centre case to the bell housing apply instant gasket sealant. The picture below shows what a bit too much sealant looks like. Quite a lot oozed out when I tightened it, meaning a fair bit must have oozed in too.
Sealant between gearbox cases
The gearbox cases bolt together. No threadlock required. Guess what? 23Nm.
Gearbox case bolts
And here is the bolt being tightened up to 23Nm in the reverse gear shaft which you aligned carefully.
Reverse gear shaft fixing bolt.
All that remains is to fit the rear case. Use sealant on the mating surfaces. Torque bolts to 23Nm.
And the gear shift plate. Sealant on mating surfaces, and thread lock on the bolts. Torque to 23Nm.
Now simply (!) refit the gearbox and away you go.
Page last edited on 21/01/2017 by user Sheepish
