This article is in the early process in the making! It should receive significant expansion in the near future.
Suzuki used to produce a factory diesel edition of Jimny, primarily for the market of Western Europe (excluding United Kingdom).
The catalogue model name for diesel Jimny edition is JB53. Its technical model name is SN415.
The marketing name for diesel Jimnys is "DDiS".
DDiS Jimnys were most popular in Portugal, Spain, Italy and France. A rough estimation is that almost every second Jimny in those countries, which was sold in the period 2003-2011, was DDiS.
DDiS Jimnys also had minor to moderate presence in several other European countries. Notable examples are Belgium, Germany and Austria. A rough estimation is that two in every ten sold Jimnys in those countries, in the period 2003-2011, were DDiS.
Note: DDiS Jimnys have never been available in United Kingdom.
Since DDiS Jimnys were produced "only" between 2003 and 2011, while petrol Jimnys have been in production since 1998 and still ongoing in 2017, DDiS Jimnys are relatively rare even in Europe.
Therefore, a potential Jimny buyer would normally be concerned what parts for the relatively rare DDiS Jimnys are specific to them, and how difficult is it to obtain those parts. Also, their typical concern is about servicing the diesel engine and other DDiS specifics.
How to spot a DDiS Jimny on the road
- All DDiS Jimnys have a prominent "power bulge" on its bonnet which looks like it has been glued to the bonnet.
- All DDiS Jimnys have a "DDiS" badge on both front wheel fenders, near side turning lights.
If 7th and 8th character in vehicle's VIN are "53", than it's a DDiS edition.
Note: Petrol Jimnys made after 2012 also have bonnet bulge, but it is different than a DDiS bonnet bulge. DDiS bulge is narrower and taller. The post-2012 petrol bulge is much wider and lower.
Both bulges are fake. They are blanked with a black plastic blanking plate, so actually no air passes through them.
A DDiS bulge actually has a technical purpose - to provide some additional space for the top of the 1.5 DCI engine to fit under the bonnet when the bonnet is closed. The intercooler in newer 63 kW DDiS Jimnys has no connection nor relation with the bonnet bulge. The intercooler is positioned low right front, just behind the front bumper.
A post-2012 petrol bulge has no technical purpose. It has only a financial purpose - to increase sales.
DDiS bonnet bulge pictures
DDiS Jimny in action
Post-2012 Jimny bonnet - picture 1
Post-2012 Jimny bonnet - picture 2
Post-2012 Jimny bonnet - picture 3
Post-2012 Jimny bonnet - picture 4
Advantages and disadvantages of DDiS versus petrol
Advantages
- Overall fuel consumption is probably the lowest among any proper all-terrain vehicle model ever produced.
- Engine's RPM-torque curve is much more biased towards 1500-2000 RPM range, which is excellent for all-terrain driving;
- Has a mean looking power bulge on the bonnet, which is different and larger than the power bulge on post-2012 petrol Jimnys;
- Engine sounds mean and utilitarian, making the vehicle appear like a larger serious 4WD truck both from inside and from outside.
The plentiful torque of the 63 kW diesel engine means that it is much less sensitive to additional load in the vehicle than the petrol engine. For example, the engine still pulls solidly even with four adult passengers inside, a roof box full of bags, four bicycles on the towbar and air conditioning on.
Disadvantages
- Availability limited to certain European countries, and in most of them it is rather rare;
- The engine weights cca 80 kg more, so vehicle's already unbalanced front-to-rear weight distribution is further worsened - slightly increasing vehicle's tendency to oversteer in bends, lose traction on uphill bends, or especially when going uphill in reverse (all this in 2WD mode);
- The engine is noisier and certainly vibrates more than the petrol, decreasing interior comfort;
- The overall reliability of Renault's 1.5 DCI diesel engines generally is not quite on the same level as the excellent reliability of Suzuki's M13 petrol engines. But "your mileage may wary" as they say!
- Vehicle is a half-breed of two completely different vehicle manufacturers. It has Renault's engine and some engine peripherals, with Suzuki's vehicle computer and some engine peripherals. So, if it develops a complicated engine issue, you will be stuck (or stretched) between two sides. Only Suzuki workshops can read and change all genuine failure/diagnostic codes, descriptions and settings, but most of those workshops have no experience and knowledge about Renault's engines. On the other hand, Renault workshops have the best knowledge and experience about servicing Renault engines, but no proper access to vehicle's ECU. You will most probably have to move the vehicle back and forth between those two to completely resolve the issue (if the two sides are that cooperative)!
- Not great for hard-core offroading, because turbocharger works only above cca 1500 RPM (standard turbocharger "turbolag" issue);
- If frequent stopping/pausing while offroading is performed (for example to take pictures etc.), the engine should not be turned off because turbocharger needs cooling down first (standard turbocharger issue);
DDiS generations
- The "1.5th" generation corresponds to "Type 5" Jimny revision in Suzuki's official technical classification;
- The 2nd generation corresponds to "Type 6" Jimny revision in Suzuki's official technical classification;
Note: For more information about Jimny "types", see wiki chapter Manuals and Owners Guides;
- The 2nd DDiS model was produced from the end of 2005 until approx 2011. The second model had several minor revisions.
Differences among the generations
The change from 1st to 2nd DDiS model occurred at the same time period when all Jimnys (both petrol and diesel) changed from manually operated 4WD transfer box to electrically operated (push-button) transfer box and from 1st generation interior trim to 2nd generation interior trim and from 1st generation front bumper to 2nd generation front bumper. This transition occurred during the second half of 2005.
- Change of engine from 48 kW (65 HP) to 63 kW (86 HP) by the addition of an intercooler.
- Different fuel filter;
- Different electrical generator and alternator;
- Different air conditioning system and piping;
- Different turbo charger;
- Different engine sensors (crankshaft, camshaft, lambda, etc.);
The summary of the changes in the engine bay is that, while the basic engine block might have remained the same, most of the peripheral engine components have changed, and an intercooler was added. This resulted in significant power and torque increase (from 160 Nm to 200 Nm). Fuel consumption remained the same, which is officially 5,6 l/100km extra-urban, 7,0 l/100km urban and 6,1 l/100km combined.
The change from 1st to 2nd DDiS model also contains many common technical changes which happened with petrol Jimnys during the same transitional period. Examples are different CV joints, front brake discs and front brake pads, handbrake cables, external side mirrors, etc.).
The newer intercooled 63 kW DCI engine requires the use of 2nd generation front bumper (to accommodate the intercooler and to feed it with air). That is why the 2nd generation front bumper was invented in the first place, but Suzuki sadly decided to bolt it onto every petrol Jimny as well from 2006 until 2012.
Additional notes
Warning:
All DDiS Jimnys with the older 48 kW (non-intercooled) engine should be avoided like the plague! The reason is a notorious catastrophic engine failure, which commonly develops in those engines. It is a common issue with those Renault engines which are found in many other vehicle models from the era of 2003-2005 (Clio for example). In short, a high pressure fuel pump starts to create metal particles, which then quickly destroy fuel injectors and even engine cylinders. The result is a total engine write-off.
There have been numerous reports of exactly that problem plaguing DDiS Jimnys with 48 kW 1.5 DCI engine. There have also been several success stories of such Jimnys achieving more than 200 000 kilometers on the odometer without a problem. But why gamble, especially when 48 kW is severely underpowered?
- To have a smaller 1st generation front bumper;
Newer 2nd generation DDiS Jimnys with 63 kW 1.5 DCI engines have different fuel injection system components which typically do not suffer from the above mentioned catastrophic failures. They also have significantly more power and torque than the 1st generation DDiS Jimnys, while retaining the same (or even better) fuel consumption.
Technical differences between DDiS and petrol Jimnys
Note on the terms in the tables:
- "Common" means that such a part is commonly shared between DDiS and at least one of petrol Jimny revisions (usually the same petrol revision which was in production at the time as the corresponding DDiS revision);
- "Specific" means that a part is unique/specific only to DDiS Jimnys. It won't fit petrol Jimnys and vice versa. Therefore, you have to buy this part specifically for a DDiS Jimny or scavenge it from another DDiS Jimny if not available. Also note that there were two major and several minor DDiS revisions, so a certain part might not even be compatible among all of them!
Suspension
| Component | Compatibility |
| Radius arms, front | Common |
| Radius arms, rear | Common |
| Radius arm bushings (all) | Common |
| Panhard rod, front | Common |
| Panhard rod, rear | Common |
| Panhard rod bushes, front | Common |
| Panhard rod bushes, rear | Common |
| Coil springs, front | Specific |
| Shock absorbers, front | Specific |
| Coil springs, rear | Common |
| Shock absorbers, rear | Common |
| Stabilizer (anti roll) bar | Specific |
| Stabilizer bar brackets | Specific |
| Stabilizer bar to chassis bushings |
Specific |
| Stabilizer bar to axle "drop" link |
Common |
| Wheel rims | Common |
| Constant velocity (CV) joint |
Common |
| Kingpin | Common |
| Kingpin bearing | Common |
| Front wheel bearing | Common |
| Rear wheel bearing | Common |
| Vacuum locking hub | Common |
| Seals (steering knuckle, halfshaft, wheel bearing, etc.) |
Common |
| Front wheel hub assembly | Common |
| Rear wheel hub assembly | Common |
| Axle differential drain and filler plugs |
Common |
| Steering column | Common |
| Steering box | Common |
| Tie rod, in front of the front axle | Specific for Santana Jimnys |
| Tie rod, behind the front axle | Specific for Santana Jimnys |
| Tie rod end, left hand tread |
| Tie rod end, right hand tread |
| Power steering pump | Specific? |
| Engine itself | Specific (obviously!) |
| Engine mounts | Specific |
| Engine cooling system | Specific |
| Fuel injection system | Specific |
| Fuel filter | Specific |
| Air conditioning system | Specific |
| Electrical generator | Specific? |
| Electrical engine starter | Specific? |
| Air filter and oil filter | Specific |
| Sensors (camshaft, crankshaft, oxygen, temperature, etc.) |
Specific |
| Catalytic converter | Specific? |
| Front differential | Specific? |
| Front halfaxle, left | Common? |
| Front halfaxle, right | Common? |
| Rear differential | Specific? |
| Rear halfaxle, left | Common? |
| Rear halfaxle, right | Common? |
| Propeller shaft from gearbox to transfer case |
Common? |
| Propeller shaft from transfer case to front axle |
Common? |
| Propeller shaft from transfer case to rear axle |
Common? |
| Universal joint for propeller shafts | Common |
| Transfer box casing | Specific? |
| Transfer box gears and components |
Specific? |
| Gearbox casing | Specific? |
| Gearbox gears and components |
Specific? |
| Front wheel vacuum locking hubs | Common |
| Vacuum system for operating front wheel hubs |
Specific (partially)* |
| Transmission lever (for older transfer boxes) |
Common |
| Transmission buttons and electrics (for newer transfer boxes) |
Common |
| Chassis | Specific (front rails strengthened) |
| Bonnet | Specific (has a bulge) |
| Engine bay internals | Specific (different layout of engine peripherals) |
| All other body panels | Common |
| ECU (computer) | Specific |
| Instrument cluster | Specific |
| Fuse and relay box | Specific? |
| Overall wiring | Partly specific |
| Lamps (driving, turn, brake, interior, etc.) |
Common |
| Fuel tank | Specific? |
| Fuel tank intake piping | Specific? |
| Fuel tank filler cap | Specific |
Note: Entire brake system is the same as in petrol Jimnys.
Note: The vacuum system for the front wheel vacuum locking hubs is located in a different portion of the engine bay. It is much more accessible in DDiS Jimnys. The vacuum is supplied directly by engine's vacuum pump which itself is directly connected to the electrical generator, while in petrol Jimnys there is no vacuum pump at all. There is no tank to store the vacuum. However, the valves and switches of the vacuum system, as well as the piping, are the same as in petrol Jimnys, except for some possible length differences in the piping. The piping scheme between the valves and the hubs are the same.
Note: The ECU (vehicle computer) is still Suzuki's despite the engine being Renault's. Suzuki adopted all engine sensors and electrics to be compatible with its ECU, and vice versa. Therefore, all diagnostic devices (including Suzuki's genuine SDT tool of course) which read Suzuki's diagnostic protocols can normally and fully access all diagnostic information and settings. On the other hand, Renault's diagnostic devices will not recognize the ECU as notning more than another generic OBD2 unit, and the most that they might read is generic standard OBD2 data (which Suzuki intentionally made to be relatively scarce to force you to come to them for full diagnostic aid).
Page last edited on 17/01/2017 by user Bosanek
