Rebuild
![Spanner Icon.png](/mediawiki/images/thumb/a/a0/Spanner_Icon.png/50px-Spanner_Icon.png)
- Range of impact sockets used to press in bearings
- 2 large flat head screw drivers
- a 2 leg gear puller and/or hydraulic press
- bearing seperator
- torque wrench(s) to cover 23-90Nm
- copper or plastic mallet
- sturdy metal tube of approx 25mm internal diameter, at least 130mm long; but see text for alternatives
Gearbox Removal
Dismantling
With the gearbox on your workbench, remove the 4 bolts holding on the gear change cover and remove. It's sealed with liquid gasket and may need a tap with a soft hammer.
Remove gear shift locating bolts, springs and ball bearings (not shown). The bearings can stick in the shafts. If you can't them out at this stage losely refit a bolt in the corresponding hole so you don't lose the bearing when you start to remove the gear shafts.
Page last edited on 11/01/2017 by user Mlines
