Lifting the vehicle
Revision as of 20:09, 29 December 2016 by Mlines (talk | contribs) (→‎Body lift)
Types of vehicle lifts
  1. Body lift
  2. Suspension lift (UK: called a spacer lift)
  3. Longer suspension (UK: called a suspension lift)
Note: The vehicle can also be lifted by installing larger (taller) tyres, which is the only way to lift the axles as well as the entire vehicle. See wiki article "Tyre selection and usage - best practices" for full details.
Body lift
Therefore, body lift does not raise any component of the chassis or the underbody away from the ground. A key benefit is that the steering is unaffected by a body lift.
  1. To look cool or mean on a budget (if that turns you on)
  2. To increase clearance between the wheels and body panels around the wheels. This then enables fitment of larger tyres, which in turn lift the entire vehicle.
Suspension lift
Note Icon.pngUK readers may be more familiar with this being a "Spacer Lift"
Installing longer suspension
Note Icon.pngUK readers may be more familiar with this being a "Suspension Lift"
Benefits, issues and risks
Benefits
  1. Vehicle lifts make your vehicle look cooler or nastier (if that turns you on).
  2. Vehicle lifts increase the ride height, increasing your self esteem.
  3. Vehicle lifts improve vehicle's off roading potency, as well as your own.
  4. Vehicle lifts make you feel you've finally done something significant to your vehicle.
Issues
  1. Suspension lift or longer suspension can significantly distort or even disrupt some vehicle's systems (steering, brake, transmission).
  2. Suspension lift or longer suspension can financially quickly spiral out of control, as they might require extensive modifications of suspension, steering and driveline components in order to compensate for technical issues.
Risks
  1. Vehicle lifts will make a car more unstable on the road. This is especially pronounced with suspension lift and longer suspensions.
  2. In some countries, in order to make the vehicle road legal, it is compulsory to perform some vehicle recertification after applying any modification the vehicle. A vehicle lift is certainly a BIG modification.
  3. Larger lifts may not be made road legal in some countries.
Note Icon.pngUK readers: Most modifications are permitted if your insurance company will insure the vehicle and it will pass the annual MOT test. A rule of thumb is that once you start cutting parts like the chassis then an SVA is required.
Warning Icon.pngModifying a vehicle can have legal consequences in some countries! The reader is responsible for checking on the local rules in their country
Additional considerations
For road use, it is technically not recommended to lift Jimny above 2" or to use spacers thicker than 3 cm.
Lift kit comparisons
Spring comparison
Manufacturer Model Number Location Free Height (mm) Spring rate (lbf/in) Notes
A B
Stock 41111-81A20 Front 335 335 120 Wire 10.3mm 7.25 turns
Rear 288 288 120 Wire 10.3mm 7.25 turns
King KSFR-36EH Front 365 365 140
KSRR-37H Rear 325 325 165
OME 40mm 2965 (petrol) Front 365 365 146 Wire 11.5mm 10 turns
2969 (diesel) Front 360 360 170 Wire 12mm 9.5 turns
2966 (RHD) Rear 335 315 176 Wire 12mm 10 turns
2967 (LHD) Rear 325 325 176 Wire 12mm 9.5 turns
Dobinson C57-046 Front 355 355 170
C57-053 Rear 340 340 165
Trailmaster 2" 76043 (petrol) Front 368 368 148 Wire 12mm
75053 (diesel) Front 353 353 205 Wire 13mm
76143 Rear 326 326 188
Trailmaster 3" 76086 Front 368 368 228
76186 Rear 355 355 240
Source:
  1. Stock - 2015 OME International Application Catalogue
  2. King - King Springs Sales and Technical Services
  3. OME - 2015 OME International Application Catalogue
  4. Dobinsons - Dobinsons Spring and Suspension International Sales
  5. Trailmaster - Maas Group GMBH and co.
Kits
Standard Jimny
Standard Jimny
An unmodified 2005 VVT Jimny (UK) for comparison.
Trailmaster 2" Lift kit
Error creating thumbnail: /bin/bash: line 1: /usr/bin/convert: No such file or directory Error code: 127
Trailmaster 2" Lift
Trailmaster 2" Lift
The Trailmaster 2" Lift
(see BigJimny Store )
Trailmaster 3" lift
Trailmaster 3" lift
Jimny fitted with Trailmaster 3" lift components
JimnyBits 2" lift
JimnyBits 2" Lift
Jimny fitted with JimnyBits 2" lift kit
KAP Suzuki 3" lift
KAP 3" Lift
Jimny fitted with KAP Suzuki 3" lift kit
Tough Dog 120mm lift
Tough Dog 120mm Lift
Jimny fitted with Tough Dog 120mm Lift (Australia) Note: I think the 120mm lift is an 80mm lift with extra spacers?
Conclusion
Page last edited on 29/12/2016 by user Mlines
