Tie rod ends
Revision as of 18:50, 23 December 2016 by Bosanek (talk | contribs) (Created page with "If Jimny is regularly used on gravel or off road, original (OEM) tie rod ends typically prove significantly more durable than aftermarket ones. Since wheel alignment has to...")
Since wheel alignment has to be performed (and paid for) after each tie-rod end change, it definitely pays off to use the best ones - OEM!
