- 1 Introduction
- 2 Quick overview of the solutions
- 3 Converting from vacuum to manually operated front wheel hub heads
- 3.1 Introduction
- 3.2 Part 1: Installing fixed or manually operated hub heads
- 3.2.1 Introduction
- 3.2.2 Solution 1a - old manual hub heads from a Samurai or a Vitara
- 3.2.3 Solution 1b - aftermarket tailor-made Jimny manual hub heads
- 3.2.4 Solution 1c - fixed hub heads
- 3.2.5 Solution 1d - converting existing vacuum hub heads into fixed hub heads
- 3.2.6 Required tools
- 3.2.7 Practical notes
- 3.3 Part 2: Blocking or removing the vacuum system (valves, pipes)
- 3.4 Part 3: Fooling or removing the 4WD controller
- 4 Final words
- 5 Useful forum discussions
Elimination of the vacuum system is worth considering in the following scenarios:
All three solutions share many common steps.
To clear any misconceptions:
This article certainly appears gargantuan and overwhelming.
It is large because it contains all the solutions for all the situations.
Only some of those will be applicable to your case and desires.
Therefore, only certain parts of this article will actually interest you.
Before hastily embarking on any of the three solutions mentioned above, you might first consider repairing your original vacuum system.
The wiki article "Vacuum hubs - checking and testing" contains the following:
- The general introduction about the purpose and operation of free-wheeling wheel hub heads;
- Description of operating systems for free-wheeling wheel hub heads;
- All the details about vacuum operated free-wheeling wheel hub heads;
- Related issues and repair solutions.
Wheel hub heads / caps are usually just shortened in naming to "hubs", but a "hub" is actually an entire wheel hub assembly - the casing which contains the wheel bearing with its seals, the steering knuckle surround casing, the king pin bearings and (in the case of the Jimny) the pipes and passages which transport the air / vacuum through the wheel hub assembly to/from wheel hub heads.
Solution with manually operated hub heads
Advantages
Disadvantages
Solution with fixed wheel hub heads
Advantages
Disadvantages
Solution with converting original vacuum wheel hub heads into fixed hub heads
Advantages
Disadvantages
Resolving incompatibility
Required parts
There are numerous versions and editions of Suzuki SJ 413s, Samurais and Vitaras / Escudos / Sidekicks / Geotrackers in existence.
Installation guide
Required parts:
Examples of aftermarket brands of tailor-made manual hub heads for Jimnys:
- AVM, hub head model 457
- Tyre X
- Various no name
- Others?
Required parts:
Beware that, in general case, the strength / robustness of modified (fixated) vacuum hub heads can never match the strength of true fixed hub heads, no matter which method to modify (fixate) them was utilized.
Conversion guide
Additional notes on spacer solutions
The summary of the choices:
- A bolt should last forever.
- Reasons:
- Reasons:
Required tools
Required tools for any of these four solutions are:
Practical notes
Reasons
Possible solutions
Disadvantages and constraints
- Vacuum metering valve;
- The check valve;
Disclaimer
Final words
And then finally comes the fun part - dislocating your butt from the armchair and actually performing this.
The following forum discussions contain some useful info:
Page last edited on 25/02/2021 by user Bosanek
