Typical weak points
- Body / cabin and suspension carriers (mounting points) on the chassis
- Various factory welding points on the chassis and on the axles as well
- Boot / trunk floor
- Below the rear seats
- Inner wheel arches
- Bodywork behind front driving lamps
Body carriers on the chassis
This chassis rail is severely weakened
This is a critical structural failure, and prevents the vehicle to be licensed for road use
Area behind the head lamps
View from the front, after the head lamp is removed
View from the back, after the front wheel inner arch liner is removed
View from the front
After sealing the seams and painting
View from the back
Front right floor section, roughly where right front passenger's right foot stands. Vibrodamping bitumen sheets had been removed prior to taking this picture.
Floor below the rear seat bench, with bitumen vibration damping compound removed
Severely rusted boot floor. Someone desperately applied wax to save it - too late and from the wrong side!
Properly and thoroughly rusted rear floor - the boot floor has already been cut off
- Salvage efforts on a thoroughly rotten rear floor section
Weld after weld after weld after weld
Notice that the entire boot floor has been replaced with a flat sheet
A lot of space has been lost by using a flat boot floor sheet
Painting then seam sealing
Close-up after work is done (note: vibrodamping materials are now missing)
General idea
- Bitumen based (the oldest and cheapest type);
- Waxes;
- Polyurethanes;
Separating body and the frame
- The only two effective methods to remove elastic compounds is to either heat them up and manually scrape them off (messy) or to extremely cool them down (with "dry ice") and then chisel them off while they are brittle.
- For example: automotive wax, bitumen-alike coating, plastic-alike coating (not recommended for outdoor applications), or polyurethane ("bed-liner") coating, etc.
General description
"Enhancing" the method
Importance of existing rust removal and bare metal surface etching
- Rust is like cancer.
- Equally as important as thoroughly removing all the rust from a surface is thoroughly roughening / keying / etching the healthy underlying surface to enable strong and long lasting adhesion of the first (direct to metal) paint coating.
- A standard method of rust removal is by using manual or powered wire brushes (attached to drills, grinders, etc.) or sand paper.
- Much more thorough rust removal can be accomplished only with sand blasting.
- Typical case where sand blasting excels over wire brushing is elimination of rust from pits, grooves etc (heavy pitted rust).
- Removing specks of rust from pits is quite difficult otherwise.
- Very rough and completely clean surface finish is required for proper adhesion of any primer paint coating over bare metal.
- The additional (extremely important) effect of sand blasting is that it also inherently thoroughly keys / etches / scars the underlying healthy surface (onto which the paint will be applied).
- If the rust is removed using wire brushes, the clean underlying surface then has to be additionally roughened / keyed / etched for proper primer paint coat adhesion, because wire brushing does not leave nearly rough enough surface (it even tends to polish it).
- Polished surface is quite the contrary to what any paint coating needs for proper strong adhesion.
- Roughening of the surface after wire brushing is usually done with 150-250 grit sand paper (two passes - second pass perpendicular to the first pass).
- This is the minimum surface roughening level required for any hope of long lasting proper paint adhesion, but a proper sand blasting will always create a profoundly rougher surface.
- If tiny specks of rust still remain after the rust removal (usually in the pits after wire brushing), the treated surfaces should then be "painted" over or sprayed over with some chemical which dissolves rust.
- Its job is to dissolve the last tiny thin remains of rust which have stayed in some pores or scratches after the mechanical removal has been performed.
- A rust treatment chemical usually needs some time (counted in minutes or even hours) to do its job.
- Popular chemicals for this purpose are phosphoric acid and hydrochloric acid.
- Inform yourself of characteristics and hazards of any acid which you intend to use, especially hydrochloric acid!
- Hydrochloric acid makes a quick genocide of the rust.
- However, it also eats away good metal too, and its vapors can corrode surrounding metal as well as your eyes and lungs if used indoors.
- If that does not scare you enough, know that it may also cause your penis to fall off.
- One positive side effect of its metal eating capability is that it will also etch / roughen the metal which it eats, making the surface more suitable for the future primer coating.
- Hydrochloric acid should not be used on any metal which has a structural bearing role (for example: chassis, tow bar, suspension arms, etc.), as it causes a fatigue in the metal due to the effect called "hydrogen embrittlement".
- Some rust elimination chemicals require rinsing them off with a suitable liquid after a certain amount of time, or even grinding them off after they harden off, while others allow further coating applications.
- Even with those chemicals which allow subsequent overcoating, it is much better to remove them from the metal (after they had done their job) and then coat directly on top of bare metal.
- Reason: It is always better to apply a primer directly onto bare metal instead onto some intermediate coating of inferior adhesion properties.
- In other words - no rust elimination chemical can be a good coating layer!
- Note that most of these rust elimination chemicals do not seal the surface against future rusting!
- The process of roughening the surface with sand papers after wire brushing should be performed after the rust elimination chemical has done its work and after it has been rinsed off and the surface has dried.
- This way, the sanding will also remove any remaining dried parts of the rust elimination chemical.
- A common misconception is that the best chemicals for eliminating rust are the so called "rust converters" - the ones which chemically alter (transform) the rust into another non-ferrous material (making it impotent).
- One of the reasons for the misconception is that such chemicals are usually much more expensive than ordinary "rust melting / elimination" chemicals, so people go by the logic "what's expensive is supposed to be effective".
- Use of magical "rust converting" chemicals should be strongly avoided.
- They are usually some form of tannic acid.
- To make the elaboration simple, two main reasons against tannic acid are:
- It rarely penetrates the rust more than its shallow surface, thus leaving its inner layers untouched.
- The converted top layer of rust prevents the corrosion inhibitors, which are usually a part of a subsequent coating like a wax or a paint primer, from performing their job.
- Reason: The converted layer behaves like a barrier between the corrosion inhibitors and the inner layer or rust under it, enabling the rust to still thrive under.
Timing and weather protection
- For example, if you sand blast a metal surface, and then load it onto a trailer to be taken somewhere else for the painting, if it's a cloudy day with high humidity (let alone rainy day!), the metal will quickly develop rust flecks ("flash rust") on the way to the next station.
- The rougher a bare metal surface, the more susceptible to flash rusting it is (that's the nature of things).
- It is also important to obey manufacturer's curing times and environmental application temperatures for each used chemical product.
- It is for this reason important to carefully observe and plan when buying various chemical products, because some products' overly quick or overly slow curing times or restrictive temperature range can complicate your working schedule and timing.
- An important exceptions to this are epoxy primer paints.
- That is one of the reasons why epoxy primer paints are the preferred type of primer coating for high quality rust proofing treatments.
- If a primer coating is porous, you need to apply final coating(s) of your choice (which need to be airtight) as soon as the primer paint dries off.
- A lot of people leave the project for a while (maybe to take a rest or a vacation) after the application of a primer paint, thinking that they have covered the bare metal and how the main "rust shield" is on, but it probably isn't!
- Thoroughly wash the underbody with soapy water or some other dirt and grease removing chemical, and then thoroughly rinse it with clean water.
- Chemically eliminate the last traces of rust on the areas where you mechanically removed rust.
- Use rust elminating acids, like phosphoric acid or even hydrochloric acid.
- Using sand paper in multiple directions, abrade / roughen up any bare metal surface or painted metal surface which you intend to overcoat.
- Reason: any new coating adheres much better on a rough surface than on a smooth surface.
- Clean and degrease the entire underbody with cleaners/degreasers and let dry completely.
- Apply anti-corrosive primer paint on all bare metal surfaces.
- It is best to use epoxy anti-corrosive primers.
- Anti-corrosive primers are those which contain rust inhibitors.
- Apply seam sealant to all previously rust-treated areas which were welded or where two metal parts/panels join together.
- It is best to use polyurethane seam sealant.
- Apply a stonechip coating of your choice (bitumen-based, polyurethane, etc.) to the entire underbody.
- Apply wax over the stonechip coating.
- Apply wax in all cavities (inside the chassis rails, inside door sills, inside doors, inside anything that is hollow.
- Take a vacation.
Final notes
- Be prepared to pay more for a thorough job execution though!
Unsorted quick tips
This chapter contains some new quick tips which were added in a haste and thus there was no time to properly incorporate them into the chapter(s).
- Read more here.
- This guide contains some very useful and practical info on DIY application of 2K high build epoxy primers.
Additional reading
Page last edited on 31/08/2020 by user Bosanek
