Revision as of 12:53, 26 June 2020 by Vecernik87 (talk | contribs) (Added Gen4 tightening torques based on User Manual)
The purpose of this page is to simply list the factory specified tightening torques for various fasteners in the vehicle.
Axle
| Item | Torque Nm | Torque lb-ft |
| Radius Arm bolts (Axle) | 90 Nm | 65 lb-ft |
| Radius Arm bolts (Chassis) | 90 Nm | 65 lb-ft |
Differential
| Diff Drain Plug | 27 Nm | 19.5 lb-ft |
| Diff Filler Plug | 50 Nm | 36.5 lb-ft |
| Prop Shaft Flange Bolts | 50 Nm | 36.5 lb-ft |
| Bevel Gear Bolts | 85 Nm | 61.5 lb-ft |
| Bearing Cap Bolts (front) | 50 Nm | 36.5 lb-ft |
| Bearing Cap Bolts (rear) | 85 Nm | 61.5 lb-ft |
| Lock Plate Bolts | 11.5 Nm | 8.5 lb-ft |
| Front and Rear carrier bolts | 23 Nm | 17 lb-ft |
| Gear Thrust Bolt (front) | 1.5 Nm | 0.1 lb-ft |
| Gear Thrust Bolt (rear) | 85 Nm | 61.5 lb-ft |
Front Hub
| Wheel Nuts | 95 Nm | 69 lb-ft |
| Tie-Rod End Nut | 43 Nm | 31.5 lb-ft |
| Kingpin Bolt | 25 Nm | 18.0 lb-ft |
| Locking Hub Bolts | 48 Nm | 35 lb-ft |
| Swivel Seal Bolts | 10 Nm | 7.5 lb-ft |
| Brake Carrier Bolts | 85 Nm | 61.5 lb-ft |
| Wheel Bearing Lock Nut | 220 Nm | 160 lb-ft |
| Drop-Link/Stabilizer Link ball nut | 50 Nm | 36.5 lb-ft |
| Brake Caliper Slider Bolt | 22 Nm | 16 lb-ft |
| Front Brake Flexi Hose bolt | 23 Nm | 17 lb-ft |
| Wheel Spindle Bolt | 50 Nm | 36.5 lb-ft |
Gearbox (R72) Post 2005
| Fill and drain plugs | 23 Nm | 17 lb-ft |
| Reverse Switch | 23 Nm | 17 lb-ft |
| 5th gear shift inverse lever bolt | 23 Nm | 17 lb-ft |
| Transmission case bolt | 23 Nm | 17 lb-ft |
| Gear shift rod spring / ball bearing bolts | 13 Nm | 9 lb-ft |
| Gearbox case to engine nuts and bolts | 90 Nm | 65 lb-ft |
Other
| Chassis to body mount bolts | 60 Nm | 44 lb-ft |
| All bolts which fasten any of the seat belts to the vehicle | 35 Nm | 26 lb-ft |
Gen 4
| Item | Torque Nm | Torque kg-m | Torque lb-ft |
| Engine oil drain plug | 35 Nm | 3.6 kg-m | 25.8 lb-ft |
| Engine oil filter (3/4 turn) | 14 Nm | 1.4 kg-m | 10.3 lb-ft |
| Manual Transmission Oil filler and level plug and Oil drain plug | 23 Nm | 2.3 kg-m | 16.6 lb-ft |
| Transfer case Oil filler and level plug and Oil drain plug | 23 Nm | 2.3 kg-m | 16.6 lb-ft |
| Front/rear differential Oil filler and level plug | 50 Nm | 5.0 kg-m | 36.2 lb-ft |
| Front/rear differential Oil drain plug | 55 Nm | 5.6 kg-m | 40.5 lb-ft |
| Wheel nuts | 100 Nm | 10.0 kg-m | 72.3 lb-ft |
Page last edited on 26/06/2020 by user Vecernik87
