Revision as of 08:39, 9 August 2019 by Bosanek (talk | contribs) (Minor cleanup)
Rear speaker installation (Jimny 3)
Most (if not all) Jimnys 3 are produced with only a front pair of speakers installed.
Jimny 3 have the factory option of having a pair of rear speakers too.
Adding a pair of rear speakers significantly improves the performance of vehicle's audio system (i.e. passengers' music listening experience).
This guide details how to install rear speakers into Jimny 3.
Tools needed
  • Small flat head screwdriver;
  • 10 mm socket & driver/ratchet;
  • #2 Philips screwdriver;
  • Electrical tape;
    • Preferably cloth electrical tape instead of PVC electrical tape;
  • Ruler or tape measure;
  • Scissors;
  • Suitable tool to pry plastic trim;
For compulsory removal of rear seats and seat belts:
  • 13 mm wrench;
  • 14 mm wrench;
If you plan do to custom DIY speaker wiring instead of obtaining OEM wiring harness for each rear speaker, you will also need:
  • Suitable automotive speaker wires;
    • 0,75 mm2 wire thickness;
      • Use 1,5 mm2 wire thickness if you plan to attach the speakers to an amplifier;
    • Preferably with silicone insulation;
    • About 0,7 m (for left speaker) + about 2 m (for right speaker) cable length;
  • Wire cutter;
  • Wire insulation stripper;
  • For those who prefer fixed soldered wire connections:
    • Soldering iron;
    • Solder coil;
    • Soldering paste;
  • For those who prefer detachable wire connections:
    • Suitable cable connectors;
    • Wire crimper;
While the rear section of vehicle's cabin interior is dismantled and removed in order to install rear speakers, you might use the opportunity to perform some additional works in the exposed cabin sections along the way.
Guide
Every Jimny 3 has factory prepared holes in the body for the rear speakers, and the common wiring connection point for both speakers is already present in the rear section of the body. However, additional wiring is required from that point to both speakers themselves (either DIY extensions or special factory harnesses).
A nice Brazilian Jimny owner wrote a very good guide on installing rear speakers in a Jimny 3.
Until the rest of this guide gets properly written, gather some more knowledge at the following forum topics:
Rest of this guide is to be written ....
