Jump to navigation
Jump to search
Suzuki offers an accessory front grille option for Jimnys 3 built between 2012 and 2018 (with separate grille from the hood) and also an accessory front grille for Jimnys 4:
- The accessory grille for Jimny 3 replaces the factory grille.
- It has the same shape, but it has chromed finish.
- The accessory grille for Jimny 4 replaces the matt black standard grille (with vertical slats and stylised 'S' logo).
- It is a gloss gunmetal grey grille with black honeycomb mesh and 'Suzuki' logo in white.
Grille replacement on Jimny 3
Info needed ...
Grille replacement on Jimny 4
- From under the bonnet remove two plastic push rivets by prising out the centre pins using a small flat-head screwdriver.
- At the bottom of the grille in the lower horizontal slot release two clips.
- Once those are done there are a series of trim clips around the indicator area and along the top edge. Just pull firmly.
Page last edited on 11/03/2019 by user Bosanek
