- This article deals with the engine drive belts and associated tensioners, their configurations and adjustment.
- Petrol Jimnys have an auxiliary belt (fan belt) and a power steering belt.
- There are a number of combinations and it is essential you get the correct belt.
- Diesel Jimnys have one auxiliary belt which drives all auxiliary engine devices.
You should not purchase based on guidance below - you should identify the correct belt for your vehicle elsewhere.
Nomenclature
For shorter naming, these abbreviations and designations will be used in this article:
- P.S. - Power Steering
- A.C. - Air Conditioning
- G13BB - petrol engine, used in very early petrol Jimnys 3 and many cabrio / open top petrol Jimnys 3;
- M13A / M13AA / M13A VVT - family of petrol engines, used in most petrol Jimnys 3 from 2001 to 2018;
- All variants of this engine are effectively the same from the "drive belt choice" perspective;
- K9K - Renault's diesel engine, used in all diesel Jimnys 3;
- This engine exists in two variants, but both are effectively the same from the "drive belt choice" perspective;
- K15B - petrol engine, used in Jimnys 4;
Belt configurations
G13BB with P.S. but without A.C.
- PAS: Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
- Shop for V-Belts in BigJimny Shop
G13BB with P.S. and with A.C.
- PAS: Adjust horizontal (TOP) of belt to 3 – 4 mm (0.12 – 0.16 in.) of flex by adjusting tensioner
M13AA with P.S. but without A.C.
- Auxillary Belt - known part number for some models 95141-50F01
- PAS:Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA with P.S. and with A.C.
- PAS+Aircon Belt - known part number for some models 17521-52E00
- PAS: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA without P.S. but with A.C.
- Aircon: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
K9K
- Info needed ...
K15B
- Info needed ...
Tensioners for Jimnys 3
There basically two types of tensioners for petrol Jimnys 3:
- One with a small center;
- These are more common on the G13B engines;
- One with a large center;
- There are more common on the M13A family of engines;
You should not purchase based on guidance below - you should identify the correct tensioner for your vehicle.
Small hole tensioner
- This is Suzuki part number 49160-82A00.
- If the bearing has worn, then it can be replaced by pressing the old bearing out.
- A suitable bearing is available in the BigJimny Shop HERE
Large hole tensioner
- This is Suzuki part number 49160-81A00.
- This tensioner is commonly called a "smilely tensioner" because of the appearance.
- If the bearing has worn then it can be replaced by pressing the old bearing out of the outer rim and pressing the smilely centre out.
Replacements
- First of all, the BigJimny shop has a high quality replacement bearing for sale (read above).
- However, if you for some reason want to replace the entire tensioner assembly (generally a lot more expensive), you can either buy the original Suzuki P.N. 49160-81A00, or one of the aftermarket tensioners.
- Example aftermarket tensioner is SKF VKM66009
- By the way, the bearing which Suzuki originally installs in this tensioner is NSK 6010DU2 (that's at least the case in M13A engined Jimnys made in 2013).
- That bearing has rubber seals on both sides.
- Specifications are: single-row, ball bearings, deep groove, 50 x 80 x 16 mm
- NSK has allegedly superseded it with the bearing model 6010DDU.
- However, since the specifications of those two bearings appear to be the same, it could very well be the same bearing, but just a changed naming nomenclature.
- There is also a "premium" edition of this bearing.
- It is NSK 6010VV.
- The "VV" suffix means that is has special "contactless" double sided rubber seals (and made of some super tech rubber), which effectively allow far higher bearing RPMs and operating temperatures.
- However, this premium bearing is about 3x more expensive than the "ordinary" one.
- This premium bearing may be an "overkill" for this application (in other words, the standard bearing may be sufficient), but an expert should give an opinion.
- However, if someone wants to indulge themselves with this premium bearing edition (instead of using chocolate or sex dolls for a change), then buy NSK 6010VV.
Tensioners for Jimnys 4
Info needed ...
Page last edited on 27/02/2019 by user Bosanek
