This chassis rail is severely weakened
This is a critical structural failure, and prevents the vehicle to be licensed for road use
General idea
- Boot / trunk floor
- Below the rear seats
- Inner wheel arches
- Bodywork behind front driving lights
- Bitumen based (the oldest and cheapest type);
- Waxes;
- Polyurethanes;
Separating body and the frame
- The only effective way to remove elastic compounds is to heat them up and manually scrape them off.
- For example: automotive wax, bitumen-alike coating, plastic-alike coating (not recommended for outdoor applications), or polyurethane ("bed-liner") coating, etc.
General description
"Enhancing" the method
Importance of existing rust removal
- Rust is like cancer.
- A standard method of rust removal is by using manual or powered wire brushes (attached to drills, grinders, etc.).
- A much more thorough rust removal can be accomplished only with sand blasting.
- Whichever mechanical rust removal procedure is performed, the treated surfaces should then be "painted" over or sprayed over with some rust treatment (elimination) chemical.
- Its job is to kill the last tiny thin remains of rust which might have stayed in some pores or scratches after the mechanical removal has been performed.
- The best chemicals for this job are the ones which chemically alter (transform) the rust into another non-ferrous material (making it impotent).
- These chemicals are much more expensive than ordinary "rust melting / elimination" chemicals.
- Prices are usually about 20-40 EUR per liter, but they are well worth it.
- An example manufacturer of these chemicals is Wurth from Germany.
- A rust treatment chemical usually needs some time (counted in hours) to do its job.
- Some of these chemicals require grinding them off after they harden off, while others allow further coating applications like it's a bare metal.
- Note that these chemicals do not seal the ruface against future rusting!
Timing and weather protection
- For example, if you sand blast a metal surface, and then load it onto a trailer to be taken somewhere else for the next phase, if it's a cloudy day with high humidity (let alone rainy day!), the metal will quickly develop rust flecks on the way to the next station.
- It is also important to obey manufacturer's curing times for each used chemical product.
- This means that you need to apply final coating(s) of your choice (which need to be airtight) as soon as the primer paint dries off.
- A lot of people leave the project for a while (maybe to take a rest) after the application of a primer paint, thinking that they have covered the bare metal and how the main "rust shield" is on, but it probably isn't!
- Remove all plugs which seal cavities (like plugs on chassis rails, door sills, etc.)
- Clean and degrease the entire underbody with cleaners/degreasers.
- Chemically eliminate the last traces of rust on the areas where you mechanically removed rust.
- Use rust elminating acids or even better rust converter/inhibitor chemicals.
- Rust converters/inhibitors work on the principle of chemically altering the rust itself, "freezing" it or chemically converting it into another substance.
- Apply anti-corrosive primer paint on all bare metal surfaces.
- It is best to use epoxy anti-corrosive primers.
- Apply seam sealant to all previously rust-treated areas which were welded or where two metal parts/panels join together.
- It is best to use polyurethane seam sealant.
- Apply a stonechip coating of your choice (bitumen-based, polyurethane, etc.) to the entire underbody.
- Apply wax over the stonechip coating.
- Apply wax in all cavities (inside the chassis rails, inside door sills, inside doors, inside anything that is hollow.
- Take a vacation.
Final notes
Page last edited on 24/02/2019 by user Bosanek
