How to spot a DDiS Jimny on the road
Notes about the bonnet bulge
- The post-2012 petrol bulge is much wider and lower, and most of it (except the front end) is one part with the bonnet.
- It is pressed out from the bonnet just like any other curve on the bodywork.
Opening the bonnet bulge
Тhis modification has not been tried in practice - it is just a theoretical idea! If you perform it, please write your experience here.
- A modification to open / unblock the DDiS bonnet bulge can be done, so that additional fresh air enters the engine bay from the above.
- Although the intercooler is not positioned in this part of the engine bay and its operation will not be affected by this modification, the general air flow through the engine bay should be improved.
- This should result in better engine performance and lower the risk of overheating it during heavy duty operation (long uphill climbs, slow off road driving, etc).
- This operation is generally irreversible, as it requires (carefully) hammering out (breaking) the plastic plug on the front of the bulge, and also cutting out the section of the bonnet below the bulge by using a grinder.
- After the unblocking is done, it is advisable to install some strong DIY grid / mesh in the bonnet bulge, in order to prevent insects or other solid objects from entering the engine bay through the hole.
DDiS bonnet bulge pictures
DDiS Jimny in action
Post-2012 petrol Jimny bonnet - picture 1
Post-2012 petrol Jimny bonnet - picture 2
Post-2012 petrol Jimny bonnet - picture 3
Post-2012 petrol Jimny bonnet - picture 4
Main vehicle specifications
- This table shows main vehicle specifications which are different in DDiS diesel Jimnys compared to contemporary petrol Jimnys.
- All information was taken from official Suzuki's documentation.
- Specifications about fluid quantities and types for DDiS Jimnys are written in the Forecourt article.
| G13BB petrol | M13A (non-VVT) petrol | M13A (VVT) petrol | DDiS K9K 700 | DDiS K9K 266 | |
| Kerb mass [kg] | 1025 - 1060 | 1045 - 1080 | 1060 - 1105 | 1138 - 1175 | 1155 - 1185 |
| Gross vehicle mass (GVM) rating [kg] |
1420 | 1420 | 1420 | 1500 | 1500 |
| Gross axle mass rating front [kg] |
680 | 680 | 680 | 780 | 780 |
| Gross axle mass rating rear [kg] |
790 | 790 | 790 | 870 | 870 |
| Engine capacity | 1298 cm3 | 1328 cm3 | 1328 cm3 | 1461 cm3 | 1461 cm3 |
| Engine power (maximum) |
59 kW at ???? RPM | 60 kW at 5500 RPM | 63 kW at 6000 RPM | 48 kW at 4000 RPM | 63 kW at 3750 RPM |
| Engine torque (maximum) |
104 Nm at 4500 RPM | 110 Nm at 4500 RPM | 110 Nm at 4100 RPM | 160 Nm at 2000 RPM | 200 Nm at 1750 RPM |
| Engine compression rating |
9.5:1 | 9.5:1 | 9.5:1 | 18.08:1 | 17.9:1 |
| Main vehicle battery |
Specifications which are common with petrol Jimnys:
- All vehicle dimensions
- Wheelbase
- Front and rear wheel track
- Ground clearance
DDiS Jimny reviews and advertisements worldwide
- There is a separate wiki article which contains the lists of Jimny reviews and advertisements worldwide, divided by languages.
- That article contains a chapter which is dedicated just to DDiS Jimnys (in any language).
- Here is the link to the DDiS chapter in the mentioned article.
Advantages and disadvantages of DDiS versus petrol
Advantages
- Much higher engine compression, providing significantly more engine braking capacity when descending downhill;
- Ability to "self set-off" and "self drive" at idle throttle;
- "Self set-off" means that you can (in most situations) start moving from still in 1st HI and reverse HI gear just by releasing the clutch pedal.
- Doing this in low range gears is even more effective.
- This can be especially useful in tight or delicate maneuvering situations.
- "Self drive" means that the vehicle is quite capable of steadily propelling itself ahead just on idle throttle except only up very steep uphill inclines.
- This way the driver can have one less thing (precise throttle application) to worry about when passing through some delicate terrain (for example some sharp rocky ground).
- In other words, it's relatively difficult to stall a diesel engine in most non-extreme all terrain driving situations.
- Higher maximum speed;
- If you are sufficiently stupid and brave, speeds of even 150 km/h are easily achievable on a good motorway!
- The bonnet bulge provides a subconscious reference point while driving;
- It also gives you a feeling of driving a big nasty 4x4 (it complements nicely with the mean diesel engine sounds);
Additional notes
- The plentiful and low-RPM torque of the 63 kW diesel engine means that it is much less sensitive to additional load in the vehicle than the petrol engine.
- Just Hit the (off)road Jack!
- at 90 km/h, 2400 RPM
- at 100 km/h, 2800 RPM
- at 110 km/h, 3000 RPM
Disadvantages
- Even the latest specimens built in 2010/2011 still conform to Euro 4 emissions specification.
- Euro 5 came into effect in late 2009.
- Has never been produced with automatic transmission.
- The engine weights cca 100 kg more, so vehicle's already unbalanced front-to-rear weight distribution is further worsened;
- This further increases vehicle's existing tendency to oversteer in bends and also to lose traction on uphill bends, or especially when going uphill in reverse (all this in 2WD mode);
- The engine is noisier / rougher and certainly vibrates more than the very smooth working G13BB and M31A petrol engines;
- This decreases interior comfort (though not nearly as much as with old agricultural diesel engines in 20th century vehicles);
- The overall reliability of Renault's 1.5 DCI diesel engines generally is not quite on the same level as the excellent reliability of Suzuki's M13 petrol engines.
- But "your mileage may wary" as they say!
- Vehicle is a half-breed of two completely different vehicle manufacturers:
- It has Renault's engine and some engine peripherals, with Suzuki's vehicle computer and some engine peripherals.
- So, if it develops a complicated engine issue, you will be stuck (or stretched) between two sides.
- Only Suzuki workshops can read and change all genuine failure/diagnostic codes, descriptions and settings.
- However, most of those workshops have no experience and knowledge about Renault's engines.
- On the other hand, Renault workshops have the best knowledge and experience about servicing Renault engines.
- But they have no proper access to vehicle's ECU.
- You will most probably have to move the vehicle back and forth between those two to completely resolve the issue (if the two sides are that cooperative)!
Additional notes
- Therefore, when offroading, sometimes 2nd low gear for going up a steep slope is not viable.
- As soon as engine RPMs drop at cca 1500 RPM, you're dead stalled.
- Note that a petrol Jimny has a similar issue, in the sense that the petrol engine "loses" significant amount of torque already below 3000 RPM, not to mention below 2500 or so.
- The difference to the diesel is that the petrol engine loses power/torque gradually as RPMs decrease, while the diesel loses them suddenly below the "turbocharger cut-off" RPMs.
| K9K 700 diesel 1461 cm3 48 kW / 65 HP |
K9K 266 diesel 1461 cm3 63 kW / 86 HP |
G13BB petrol 1298 cm3 59 kW / 80 HP |
M13A petrol 1328 cm3 60 kW / 82 HP |
M13A VVT petrol 1328 cm3 63 kW / 86 HP | |
| Urban | 7,0 | 7,0 | 10,2 | 9,5 | 9,3 |
| Extra-urban | 5,6 | 5,6 | 7,1 | 6,8 | 6,3 |
| Combined | 6,1 | 6,1 | 8,2 | 7,8 | 7,3 |
| Data source | Suzuki brochure | Suzuki brochure | www.mobile.de | www.mobile.de | Suzuki brochure |
Notes:
- The fuel consumption statements are the same for both the older 48 kW K9K 700 engine and for the newer 63 kW K9K 266 engine.
- This is not an error.
- All stated fuel consumption figures are " ideal / official / laboratory / etc." figures.
- Therefore, they might not be accurate in real life (just like for any other vehicle).
- On difficult gravel roads and off road terrain, fuel consumption varies widely based on the conditions.
- It is typically around 8-11 l / 100 km, but it can be as high as 15 l / 100 km in severe conditions.
- The overall average fuel consumption after 30 000 km of all roads, terrains and conditions is 7,3 l / 100 km.
- This figure might vary significantly for other people, based on what, on what, through what, with what, without what, where, how, with who and without who they drive.
DDiS generations
- Different fuel filter;
- Different turbo charger;
- Examples are different CV joints, front brake discs, handbrake cables, external side mirrors, etc.
- The newer intercooled 63 kW DCI engine requires the use of the much larger 2nd generation front bumper (to accommodate the intercooler and to feed it with air).
Additional notes
Notes on factories
Notes on K9K engines
General information
- On those vehicles, the engine can be recognized by having the same 48 kW of power.
- However, the compatibility of every engine part, sensor and peripheral device against the engine used in DDiS Jimny may vary.
- Investigating all that would be a grand project!
- On those vehicles, the engine can be recognized by having the same 63 kW of power.
Forum user Bosanek had personal experience with successfully using the following OEM Renault or aftermarket engine parts in his own DDiS 2nd gen. (type 6) Jimny:
| Part description | Suzuki P.N. | Part actually used | Alternatives | Notes |
| Timing belt kit (timing belt and timing belt tensioner) |
12760-84A50 (most probably!) |
Genuine Renault (P.N. 77 01 477 028) |
Others available | None |
| Accessory drive belt (serpentine belt, V-belt) |
95141-84A00? | Genuine Renault (P.N. unknown) |
Others available | P.N. unknown because mechanic obtained the part |
| Water pump | 17410-84A11 | Genuine Renault (P.N. unknown) |
| Glow plug(s) | 18550-84A51 | SWAG 30 91 7979 | Many others available | Old (probably factory fitted) glow plug was Beru "0 100 226 504" with "Renault 82 00 464 077" also written on it |
| Camshaft sensor | 33220-84A10 (type 6) 33220-84A20 (type 7 from JSAFJB53V00451107) |
Metzger 0903038 | Many others available | None |
| Camshaft front oil seal | 12746-84A01 | Genuine Renault, P.N. unknown | Others available | P.N. unknown because mechanic obtained the part |
| Crankshaft sensor | 38930-76A00? | Metzger 0902052 | Many others available | None |
| Crankshaft oil seal, front | 16114-84A00 | Not replaced yet | ? | Haven't had a failure yet |
| Crankshaft oil seal, rear | 16121-84A00 | Not replaced yet | ? | Haven't had a failure yet |
| Cylinder head gasket | 11179-84A00 | Not replaced yet | ? | Haven't had a failure yet |
| Inlet metering valve (fuel pressure regulator) for the high pressure fuel pump |
15213-84A00 | Delphi 9109-903 | No other models or makes appear to be compatible |
Alternate P.N.s: 1. Delphi 28233373 2. Delphi 9307Z523B |
| Coolant temperature sensor | 13660-84A01? | Metzger 0905159 | Others available | Acquired preventively but not yet installed |
| Oil pressure switch | 37820-84A01 | Not replaced yet | ? | Haven't had a failure yet |
| Inlet air temperature sensor | 13650-84A00 | Not replaced yet | ? | Haven't had a failure yet |
| MAF sensor | 13800-84A50 | Not replaced yet | ? | Haven't had a failure yet |
| MAP sensor | 18590-84A51 | Not replaced yet | ? | Haven't had a failure yet |
| EGR valve | 18520-84A53 | Not replaced yet | ? | Haven't had a failure yet |
| Electrical generator pulley | 31171-84A10 | Febi Bilstein 47589 | Others available (Ina 535 0233 10 should fit) |
None |
| Fuel filter | 15410-84A51 | 1. Genuine Suzuki 15410-84A51 2. Mann WK 9008 3. Mahle/Knecht KL 404 |
Many others available | The filter in Suzuki's genuine packaging was in fact Mahle/Knecht KL 404 - high quality |
| Air filter | 13780-84A00 | Japanparts FA-823S | Many aftermarket brands available | None |
| Oil filter | 16510-84A11 | Blue Print ADN12121 | Many aftermarket brands available | None |
| Gasket, oil pan | 11529-84A01 | Corteco 028121P | No other aftermarket brand OEM Renault 82 00 312 820 or 82 00 379 654 |
Haven't actually installed it yet, but I'm 90% certain |
| Oil pan drain screw / plug | 11518-63J10 | Many other available | ? | Any equivalent screw fits |
Issues and solutions with K9K engine failures
K9K 700 engine specific
- The fuel pump usually starts to disintegrate at a certain point, wrecking the injection system (your mileage may vary!).
- Preventive replacement of those plates every 70 000 - 100 000 km is highly recommended (especially since it's generally not labor intensive and the parts cost "only" circa 100 EUR).
- It appears that replacing the connection rod plates might actually be a major undertaking regarding the amount of labor. See the notes on K9K 266 engine below.
K9K 266 engine specific
- Even so, preventive replacement of those plates every circa 100 000 km is a sound idea, since it's generally not labor intensive and the parts cost "only" circa 100 EUR.
- It appears that replacing the connection rod plates on K9K 266 engines actually requires a significant amount of labor, as the plates allegedly can not be reached from the bottom of the engine by simply removing the engine oil sump.
- First of all, in order to completely remove the engine oil sump out of the way, the prerequisites are the removal of the lateral rod, and at least one tie rod (they block the space underneath).
- Even with the engine oil sump completely removed out of the way, only the oil pump can be reached and serviced.
- The connection rod plates are still inaccessible behind an additional "cage" acting as a "middle sump".
- The part number of the cage / middle sump is 11522-84A51, and it can be clearly seen as item #1 on Suzuki's technical parts diagram E22_010 (link to diagram).
- The main oil pan is item #5 in the diagram.
- The cage / middle sump allegedly can not be removed with the engine in place - the whole engine has to be removed from the engine bay first!
- So, replacing the connection rod plates on a K9K 266 engine requires a complete engine removal and dismantling half of the engine!
- This was all stated by an experienced Renault mechanic (who used to work for years for an official Renault service firm), after actually trying to replace the connection rod plates on a K9K 266 engine (2nd gen DDiS Jimny).
- This same constraint is probably valid for K9K 700 engines as well, because they also have a very similar "middle sump"
- It's part number is 11522-84A00, portrayed as item #1 on Suzuki's technical parts diagram E22_010.
EGR valve
- EGR valve, if not maintained regularly, tends to stick and allow hot exhaust air to constantly pass through.
- An intermittent loss of power, followed by a bust of power and a puff of black smoke - that's unburned fuel.
- A hood idea is to check the injectors and the fuel filter!
- If there is a constant plume of blue smoke during engine idling, that means that the engine is burning oil.
- It's probably something like worn piston rings (compression test can determine that).
- The other cause of blue smoke is a very badly failing turbo charger (loads of oil burning).
- This white/blueish smoke is heavily prominent during acceleration above 2000 RPM.
Oil around the turbo charger
- This is not a major issue, but for the relatively low price, it is not a bad idea to keep the elements clean.
Tips for care and maintenance of K9K engines
Most of the advices below are generic for all turbocharged diesel engines, not just for Renault's K9K engines.
Important elements of care
- Do not drive off immediately after starting a cold engine.
- In the summer time, wait at least 10 seconds.
- In the winter time, wait at least 30 seconds, or at least a minute in freezing temperatures.
- Do not shut the engine off immediately after stopping, especially after high speed driving, driving uphill or driving off road (in short, under load)!
- Idle the engine for at least a minute after stopping in such situations, so that the turbocharger cools off through the flowing oil.
- Otherwise, turbocharger's bearings can be damaged.
- This is a standard issue with all turbocharged engines.
- Avoid "revving" the engine hard in any condition (above 3500 RPM). Preferably keep the engine RPMs under 3000 RPM.
- There isn't much benefit in "revving" a diesel engine in general, as their torque curve is biased much more around 2000 RPM range.
- Do not use very strong throttle in low engine RPMs (<= ~1800 RPM).
- This puts excessive load on certain vital parts of the engine (connecting rods, crankshaft, etc.).
- The turbocharger won't be delighted either.
- If RPMs drop to <= ~1600 RPM, downshift to lower gear!
- During such low RPMs, turbocharger's lubrication will be on the minimum verge of its operating norm.
- Throttling it then is the worst thing to do.
- Don't be lazy - change to lower gear and then apply the throttle!
- The vehicle should be periodically (at least once a year) taken on a motorway to be "burned out" - driven hard on ~3200 RPM in 4th gear at ~100 km/h continuously for at least 15 minutes.
- That will burn out accumulated soot deposits in certain parts of the engine and in the exhaust system (catalytic converter, DPF, etc.).
- This is especially important if the vehicle is used predominantly in city traffic or off road.
- This is best combined with using a fuel injection system treatment chemical (see more below), and with relatively fresh engine oil.
- Use high quality engine oil and oil filter and change them every 10 000 km or even sooner (manual says every 15 000 km - that is too optimistic).
- For frequent off road driving, use oil + filter changing intervals of 7000-8000 km.
- Change the air filter with each engine oil change.
- Don't skimp by just cleaning it!
- Have the EGR valve cleaned of soot, as well as EGR valve's and turbocharger's connecting pipes cleaned of soot and other deposits in regular intervals.
- Recommended intervals are each 20 000 - 30 000 km, or every 50 000 km in the worst case.
- You might consider periodically using engine flushing chemicals to flush the engine when changing engine oils.
- A possibly recommended interval might be every 50 000 km.
- However, this is a somewhat controversial topic in general, so you should perform the final investigation about the risks of this procedure in general.
- Do not use low quality diesel fuel!
- The fuel injection systems of DCI engines are quite sensitive and delicate, and low quality fuel can produce many headaches (intermittent annoying issues or even permanent and expensive damage).
- Avoid letting the fuel level in the fuel tank drop to the reserve.
- This way gum and deposits from the bottom of the fuel tank could get sucked into the delicate fuel distribution and injection system.
- Use only high quality fuel filters.
- Proven high quality fuel filters for 2nd gen. (63 kw) DDiS Jimnys are Mahle/Knecht KL 404, Mann WK 9007, Valeo 587544, etc.
- There are other high quality brands of course.
- Replace the fuel filter in regular intervals.
- It's a rather simple job and the filter is freely accessible in the engine bay.
- The manual says that the replacement interval is every 45 000 km, but this highly depends on the fuel quality in your country.
- For example, many Eastern and South Eastern European countries are notorious for the presence of very low quality fuels, so much that some vehicle manufacturers do not sell their diesel vehicles in such countries at all.
- In such circumstances, the fuel filter should be replaced every 30 000 km, preferably every 20 000 km - it's your choice!
- You might consider periodically using fuel flushing (fuel injection system cleaning) chemicals to flush the fuel in the fuel tank, fuel piping and clean the fuel injectors.
- If high quality chemicals are used, there should not be any risk of side effects.
- Renault sells a "diesel fuel injection system treatment" chemical which is allegedly specifically made for their DCI engines.
The procedure of using a fuel injection system treatment chemical
- Buy a fuel injection system treatment chemical of your choice.
- Stop at your desired fuel station.
- Before pouring the fuel, pour the fuel treatment chemical in the fuel tank.
- Now pour in diesel fuel until the fuel tank is half full (to achieve double density of the chemical in the fuel).
- This is approx. 15-20 l for DDiS Jimnys.
- Drive hard in the following period until you almost empty the fuel tank.
- The best way is to drive on the motorway in 4th gear but at the same speed as you would normally drive in the 5th gear.
- For example, drive at 100 km/h in 4th gear continuously for at least 15 minutes.
- That will be around 3200 RPM and will burn out any deposits in the engine and the exhaust (catalytic converter, DPF etc.).
- More importantly, it will pump high fuel flow (together with the mixed in fuel treatment chemical) through the fuel injection system, which should "rinse" it properly.
- Replace the fuel filter.
- Use a high quality replacement filter.
The best time to use fuel treatment chemicals is shortly before the planned schedule to change the fuel filter.
Also, the oil in the engine should be relatively new (not "older" than ~5000 km).
It is not advised to perform this procedure when engine oil is worn/old (due to be replaced soon)!
Appearance of a typical fuel filter used in K9K 700 engines (1st gen. DDiS Jimnys)
Appearance of a typical fuel filter used in K9K 266 engines (2nd gen. DDiS Jimnys)
Servicing K9K engines
"Official and expensive" method of obtaining parts
"Trial-and-error and cheap" method of obtaining parts
Servicing the engine and engine peripherals
- It is highly recommended to conduct a personal research of the issue beforehand, so that you are at least approximately acquainted with the issue when you appear at the workshop.
Computer diagnostics
- However, the service manual clearly states that, with OBD2 protocol, ECU's provided set of information, level of detail, and depth of access is severely restricted.
- It is confined to minimum legal requirements set by the OBD2 standard.
Suzuki SDT reading DCTs from DDiS ECU - example 1
Suzuki SDT reading DCTs from DDiS ECU - example 2
Suzuki SDT reading ECU ID from DDiS ECU - example 1
Issue with a 3-way coolant pipe on gen. 2 DDiS Jimnys
If you notice engine coolant leaks below the engine bay of your 2nd gen. DDiS Jimny (with 63 kW), you might have a relatively common failure of one small, simple, but nasty coolant system part.
- The labor cost of its complicated replacement is relatively high (half of the engine has to be disassembled to reach it and to be able to maneuver around it).
If the original replacement part is not available in time, or if you desire a permanent lifelong solution, there is an unconventional alternative:
- Bosanek did it that way, and the copper DIY pipe is still holding strong after 30 000 km.
- These three pictures contain a red arrow which points to the location of the 3-way pipe
Overview of the location of the 3-way pipe in the engine bay of a 2nd gen. DDiS Jimny
Closer view of the location of the 3-way pipe in the engine bay of a 2nd gen. DDiS Jimny
Close-up of the 3-way pipe in the engine bay of a 2nd gen. DDiS Jimny
- Here are the parts themselves
Genuine Suzuki 3-way coolant pipe 17878-84A50, worn
Replacement DIY copper 3-way coolant pipe next to the original worn 3-way coolant pipe
Improving air flow through the intercooler on gen.2 DDiS Jimnys
- 2nd gen. DDiS Jimny with its (2nd gen) front bumper removed
Technical differences between DDiS and petrol Jimnys
- "Common" statement means that such a part is commonly shared between DDiS and at least one of petrol Jimny revisions.
- It is usually at least the same petrol revision ("type") as the DDiS revision ("type").
- In other words, it means compatibility with petrol vehicles which were in production at the time as the corresponding DDiS revision;
- "Specific" statement means that a part is unique/specific only to DDiS Jimnys.
- It won't fit petrol Jimnys and vice versa.
- Therefore, you have to buy this part specifically for a DDiS Jimny (in the aftermarket if available, otherwise from Suzuki) or scavenge it from another DDiS Jimny.
- Also beware that some "DDiS specific" parts are compatible only with the 1st or the 2nd DDiS generation.
- Read the notes in the tables for details!
- A dot (".") statement suffix means that a statement is confirmed by comparing part numbers between petrol and DDiS Jimnys in Suzuki's official vehicle parts catalog.
- Some statements are additionally confirmed in practice (as indicated in the table).
- A question mark ("?") statement suffix means that the statement is not confirmed from Suzuki's official parts catalog and/or in practice.
- Therefore, it's an assumption based either on some 3rd party catalogues, or on Internet "hearsay", or on claims by 3rd party vehicle parts shops, or just on general logical reasoning.
- Also beware that Jimnys built by Santana in Spain (both petrol and diesel) might have some parts specific to them only!
- Spanish Jimny's VIN's begin with VSE....
Suspension parts
| Component | Compatibility | Checked in practice? | Notes |
| Radius arms, front | Common. | No | None |
| Radius arms, rear | Common. | No | None |
| Radius arm bushings (all) | Common. | No | All radius arm to chassis bushings were improved in 2007 (just like in petrol Jimnys) to fight death wobble |
| Panhard rod, front | Common. | No | Common with LHD petrol Jimnys only (all RHD Jimnys have a front panhard rod specific to them) |
| Panhard rod, rear | Common. | No | None |
| Panhard rod bushes, front | Common. | No | None |
| Panhard rod bushes, rear | Common. | No | None |
| Coil springs, front | Specific. | No | Stronger to cope with extra weight in the engine bay DDiS P.N.: 41111-84A00 (per piece) - used by all DDiS Jimnys |
| Shock absorbers, front | Specific. | No | Stronger to cope with extra weight in the engine bay DDiS P.N.: 41600-84A00 (per piece) - used by all DDiS Jimnys |
| Coil springs, rear | Common. | No | Common with LHD petrol Jimnys only (all RHD Jimnys have rear springs specific to them) |
| Shock absorbers, rear | Common. | No | None |
| Stabilizer (anti roll) bar | Specific. | Yes, on type 6 DDiS | Bar diameter 28 mm (significantly thicker than in petrol Jimnys) DDiS P.N.: 42311-84A00 - used by all DDiS Jimnys |
| Stabilizer bar bushing brackets |
Specific. | Yes, on type 6 DDiS | Larger to accommodate larger bushings DDiS P.N.: 42415-84A00 - used by all DDiS Jimnys |
| Stabilizer bar to chassis bushings |
Specific. | Yes, on type 6 DDiS | Inner diameter 28 mm, outer diameter also larger DDiS P.N.: 42412-84A00 (per piece) - used by all DDiS Jimnys |
| Stabilizer bar to axle "drop" link |
| Wheels | Common. | Yes, on type 6 DDiS | None |
Drivetrain parts
| Constant velocity (CV) joint |
Common. | Yes, on type 6 DDiS | For all Jimnys: CV joints in type 5 and newer are different than in type 4 and older |
| King pin | Common. | Yes, on type 6 DDiS | None |
| King pin bearing | Common. | Yes, on type 6 DDiS | None |
| Front wheel bearing | Common. | Yes, on type 6 DDiS | |
| Rear wheel bearing | Common. | No | None |
| Vacuum wheel locking hub head | Common. | Yes, on type 6 DDiS | For all Jimnys: Vacuum locking hub heads in type 5 and newer are different than in type 4 and older |
| Seals (steering knuckle, halfshaft, wheel bearing, etc.) |
| Front wheel hub casing | Common. | Yes, on type 6 DDiS | This casing holds the wheel bearing, kingpin bearings etc. For all Jimnys: Wheel hub casings in type 5 and newer are different than in type 4 and older |
| Front axle casing | Specific. | No | Minor differences in coil spring seats and shock absorber mounts to cope with the stronger coil springs and shock absorbers. An axle swap is possible depending on the coil springs and shock absorbers to be installed. Some components are not compatible between LHD and RHD vehicles. Used by all DDiS Jimnys. |
| Rear axle casing | Common. | No | An axle swap is possible. Rear axle casing differs for non-ABS and ABS models (irrespective of LHD or RHD). Used by all DDiS Jimnys. |
| Axle differential drain and filler plugs |
Common. | Yes, on type 6 DDiS | Common for both front and rear |
Steering parts
| Steering column assembly | For 1st gen. DDiS: Common except column itself and the cover. For 2nd gen. DDiS: Common except the cover. |
No | 1a. The column itself in petrol Jimnys in type 5 and newer is different than in type 4 and older. 1b. The column in 2nd gen. DDiS matches the newer column from petrol Jimnys. 2. The difference in the cover (casing) might just be cosmetic |
| Steering box | Specific. | No | DDiS P.N.: 48600-84A80 |
| Steering box pitman arm | Specific. | No | DDiS P.N.: 48671-84A80 |
| Tie rod, in front of the front axle |
Common for Jimnys made in Japan. Specific for Santana Jimnys. |
No | See note below |
| Tie rod, behind the front axle |
| Tie rod end, left hand tread |
No | See note below (note missing!) |
| Tie rod end, right hand tread |
| Power steering pump, pulleys and piping |
Specific. | No | None |
| Power steering oil tank | Common. | No | None |
Engine and engine peripherals parts
| Engine itself | Specific (obviously!) | No need | None |
| Engine mounting bushes, front | Specific. | No | Two are used per engine (left and right) |
| Engine mounting bush rear ("gearbox mount") |
Specific for 1st gen. DDiS. Common for 2nd gen. DDiS. |
No | One is used per engine |
| Engine cooling system | Specific. | Yes, on type 6 DDiS | The engine cooling system also differs between 1st and 2nd DDiS generation. |
| Fuel injection system | Specific. | Obvious | The fuel injection system also differs between 1st and 2nd DDiS generation. |
| Fuel filter | Specific. | Yes, on type 6 DDiS | The fuel filter also differs between 1st and 2nd DDiS generation. |
| Air conditioning system | Specific. | ||
| Electrical generator | Specific? | ||
| Electrical engine starter | Specific? | ||
| Air filter and oil filter | Specific. | ||
| Sensors (camshaft, crankshaft, oxygen, temperature, etc.) |
Specific. | ||
| Catalytic converter | Specific? |
Transmission parts
| Front differential casing | Common. | ||
| Front differential gears and components | Specific. (partly?) | See notes below | |
| Front halfaxle, left | Common? | ||
| Front halfaxle, right | Common? | ||
| Rear differential casing | Common. | ||
| Rear differential gears and components | Specific. (partly?) | See notes below | |
| Rear halfaxle, left | Common? | ||
| Rear halfaxle, right | Common? | ||
| Propeller shaft from gearbox to transfer case |
Common? | ||
| Propeller shaft from transfer case to front axle |
Common? | ||
| Propeller shaft from transfer case to rear axle |
Common? | ||
| Universal joint for propeller shafts | Common. | ||
| Transfer box casing | Specific for lever shifted type? Common for electrically shifted type? |
See notes below the table | |
| Transfer box gears and components |
| Gearbox casing | Specific. | See notes below the table | |
| Gearbox gears and components |
| Front wheel vacuum locking hub heads | Common. | ||
| Vacuum system for operating front wheel hub heads |
Specific (partially) | See the chapter #Notes on the vacuum system for front wheel hub heads for details | |
| Transmission lever (for older transfer boxes) |
Common. | ||
| Transmission buttons and electrics (for newer transfer boxes) |
Common. |
- It has been confirmed that the gearbox casing from DDiS Jimnys is completely different than from any petrol Jimny (it is specific to DDiS Jimnys).
- This indicates that probably most (or all) gears in the gearbox are specific to DDiS Jimnys, but this has not been confirmed.
- It is currently unknown if the gearbox seals are specific or common.
- It appears (from the diagrams) that the gearbox casing is the same in 1st gen. and 2nd gen. DDiS Jimnys, but this has not been confirmed.
- It appears that the code name of the 1st gen. DDiS gearbox is "YR7D".
- Source: photographs of a dismounted gearbox from a 1st gen. DDiS Jimny.
- The code is written on a factory glued paper note on the gearbox casing.
- The lever shifted transfer case's casing from 1st gen. DDiS Jimnys is completely different than from petrol Jimnys.
- This indicates that the gears inside might be specific as well, as well as the connection points with the propeller shafts.
- But this is not verified.
- The electric push-button transfer case's casing in DDiS Jimnys appears to be the same as in petrol Jimnys which have the same (push-button) type transfer box.
- However, this does not guarantee that the gears inside are the same and that the connection points with the propeller shafts are the same.
- The transmission ratio of DDiS differentials is specific to DDiS Jimnys - it is 3.416.
- All DDiS Jimnys have the same differentials.
- However, some parts of the differential (like spider gears or bearings) might be common with some petrol Jimny differentials.
- This has not been thoroughly investigated yet.
- The code name of DDiS rear differential is "J12F".
- Source: photographs of a dismounted rear differential from a 2nd gen. DDiS Jimny.
- The code is factory stamped on the gearbox casing, like a graffiti.
Brake system parts
| Brake disc | Specific. | Yes | DDiS Jimnys use two types of brake discs, both specific to them:
| Brake pad | Specific. | Yes | All DDiS Jimnys use pads P.N. 55200-84A00 |
| Brake caliper | Specific. | Yes | Left and right brake calipers are different |
| Brake drums | Common. | Yes | None |
| Brake shoes | Common. | Yes | All Jimnys type 5 and newer use different brake shoes (53200-76J00) than Jimnys type 4 and older (53200-81A11). |
| Brake cylinder | Common. | Yes | None |
| Master cylinder | Specific. | No | All DDiS Jimnys use master cylinder 51100-84A60 (1st edition) and 51100-84A61 (minor revision). Older and newer edition should be interchangeable. |
| ABS pump (actuator) | Common. | Yes | All Jimnys type 5 and newer use different ABS pump / actuator (56100-76JA0) than Jimnys type 4 and older (56100-81A11). |
| Sensor, front wheel | Specific. | No | All DDiS Jimnys use front wheel ABS sensors 56200-84A00 |
| Sensor, rear wheel | Common. | No |
Body parts
| Chassis | Specific. | Front rails strengthened - obviously different look. Other chassis elements not investigated. | |
| Bonnet | Specific. | It has a specific fake power bulge glued onto it, with a hole in the bonnet below it to accommodate the K9K engine. | |
| Engine bay internals | Specific (obviously!) | Vastly different layout of engine peripherals. | |
| All other body panels | Common. |
Electrical parts
| ECU (computer) | Specific. | ||
| Instrument cluster | Specific. | Some warning lights are specific for diesel engines. | |
| Fuse and relay box in the engine compartment |
Specific. | ||
| Fuse box under the dash board |
| Overall wiring | Partly specific. | Details are to "tangled up" to elaborate. | |
| Lamps (driving, turn, brake, interior, etc.) |
Common. |
Fuel tank system parts
| Fuel tank | Specific? | ||
| Fuel tank intake piping | Specific? | ||
| Fuel tank filler cap | Specific. |
Other parts
| Cabin (pollen) filter | Common. | Yes | Example product is Blueprint ADK82502 |
| Throttle pedal assembly | Specific. | No | None |
| Brake pedal assembly | Common. | No | None |
| Clutch pedal | Common. | No | None |
| Clutch pedal small back lever | Specific. | No | None |
- In DDiS Jimnys, the vacuum system for the front wheel vacuum locking hub heads is located in a different portion of the engine bay than in petrol Jimnys.
- The vacuum is supplied directly by engine's vacuum pump (which itself is directly connected to the electrical generator).
- In petrol Jimnys there is no vacuum pump at all.
- The piping scheme between the valves and the wheel hubs are the same.
If you suspect that your vacuum system has issues, read the wiki article "Vacuum hubs - checking and testing".
Notes on vehicle computer systems
- On the other hand, Renault's diagnostic devices will (most likely) recognize the ECU as nothing more than another generic OBD2 unit.
- Therefore, the most that they would most likely be able to read is generic standard OBD2 data (which Suzuki intentionally made to be relatively scarce to force you to come to them for full diagnostic aid).
Page last edited on 18/07/2018 by user Bosanek
