- 1 Introduction
- 2 Solution with manually operated hub heads
- 3 Solution with fixed wheel hub heads
- 4 Converting from vacuum to manually operated front wheel hub heads
- 4.1 Introduction
- 4.2 Part 1: Installing manually operated hub heads
- 4.3 Part 2: Blocking or removing the vacuum system (valves, pipes)
- 4.4 Part 3: Fooling or removing the 4WD controller
- The purpose of this article is to provide you an alternative solution to repairing that system - replacing it altogether with manually operated free-wheeling front wheel hub heads.
- Even fixed front wheel hub heads can be installed (the procedure is almost the same) - this is also covered in this article.
The wiki article "Vacuum hubs - Checking and testing" contains the following:
- The general introduction about the purpose and operation of free-wheeling wheel hub heads;
- Description of operating systems for free-wheeling wheel hub heads;
- All the details about vacuum operated free-wheeling wheel hub heads;
- Related issues and repair solutions.
Wheel hub heads / caps are usually just shortened in naming to "hubs", but a "hub" is actually an entire wheel hub assembly - the casing which contains the wheel bearing with its seals, the steering knuckle surround casing, the king pin bearings and (in the case of the Jimny) the pipes and passages which transport the air / vacuum through the wheel hub assembly to/from wheel hub heads.
Reasons and advantages
- However, there is luckily an alternative solution - to completely discard the vacuum system and vacuum front wheel hub heads, and install manually operated free wheeling front wheel hub heads (like in Samurais and other classic 4WD vehicles) or even fixed hub heads.
- Manually operated free wheel wheel hub heads generally have the lowest risk of failures, as there is by far the least amount of components which can fail.
- The modification is relatively simple to perform, with required parts widely available on the second hand market and/or in the aftermarket.
- If you just want to preventively minimize the risk of a failure;
Disadvantages
- As most manual free wheeling hub heads have no anti-tamper mechanisms, a malicious person can easily (dis)engage a hub head while the vehicle is parked (easily remedied by the driver when detected, but can cause confusion while driving in the meantime).
- If water enters into a manual free wheeling hub head, it can freeze the manual (un)locking spring mechanism in the hub head during frigid weather. If this happens while the hub head is disengaged, it can prevent the vehicle from using 4WD transmission when it is needed the most.
- It is also possible to install fixed hub heads.
- One possible source of obtaining fixed hub heads would be from a vehicle junkyard which has a dead "el cheapo" 2WD-only Jimny (quite rare, produced from 1998 to 2001).
- The only difference in the end will be that you will never be able to disengage the front wheels from the drive line.
- They are theoretically more durable for extremely heavy-duty operation;
- There is an alternative unorthodox solution to modify Jimny's original vacuum-operated front wheel hub heads so that they become fixed (always engaged).
- The advantage of this solution is that no new (replacement) fixed hub heads are needed.
- It can be accomplished in a few ways.
- That topic is thoroughly discussed in this BigJimny forum topic.
It is vital in understanding why some steps in the procedure are performed.
- There are two solutions on how to achieve it.
Required parts for solution 1 (less expensive, more fiddling around):
- A pair of manually operated, second hand hub heads from a Suzuki SJ413 (Samurai) or from a Suzuki Vitara (Escudo / Sidekick / GeoTracker) Mk1.
- Since the hub heads from earlier Suzuki vehicles do not fit directly on a Jimny, a pair of special spacers/adapters (with suitable bolts), which sit between these hub heads and the wheel hub assembly, is also required.
- Browse the shops like BigJimny, JimnyBits, Bits4Vits, etc. for these spacers/adapters.
There are numerous versions and editions of Suzuki SJ413s, Samurais and Vitaras in existence.
Required parts for solution 2 (more expensive, more elegant):
- These are a direct "bolt-on" replacement - no spacers/adapters needed!
Required tools:
Reasons
- After the first part of the conversion is complete, you will be able to manually (dis)engage the front wheels from/to the front drive line at will.
- However, the vacuum system will be left "hanging in the air", doing its job in the void (literally) - trying to achieve vacuum in vain.
- It will NOT be possible to shift between2WD<->4WD-H transmission modes, as the 4WD controller electromagnetically operates the (dis)engagement mechanisms in the transfer box after your push-button invocation.
Possible solutions
- Solution 1 is to block the pipes in the vacuum system, forcing the formation of the vacuum.
- Solution 2 is to remove the entire vacuum system from the vehicle, and then to modify the wiring to simulate the return signals from the vacuum system to the 4WD controller.
Solution 1 - blocking the vacuum system
- Solution 1 is a simpler solution - just to block the vacuum pipes, so there will be no leaks in the vacuum system.
By performing this solution in part 2 of the conversion, you have automatically accomplished part 3 of the conversion (fooling the 4WD controller) and your work is done!
- At the valves in the engine bey - disconnecting the pipes from the valves and then blocking both the pipes and the valves.
Disadvantages and constraints
"simulate a return signal from the vacuum system to the 4WD controller (the signal which informs the controller if the vacuum has formed when the operation of the vacuum system is invoked).
Solution 2 - discarding the entire vacuum system
- Vacuum metering valve;
- The check valve;
- This part of the conversion is performed only after removing the vacuum system in part 2 of the conversion.
- In other words - if you decided to block the vacuum system (solution 1) in part 2 of the conversion process, then you do not need to do anything in part 3 - your conversion is already done!
Solution 1 - fooling the 4WD controller
- Reason for the short circuit: This valve used to short-circuit this connector whenever it sensed a successful vacuum formation. By permanently shorting the wires, the 4WD controller will always believe that the vacuum system is working fine. A permanent short circuit condition should not harm it (theoretically).
Solution 2 - removing the 4WD controller
- This will "free" the vehicle of all electronic / smart / modern / vulnerable elements of the 4WD transmission system. It will be as classic as a Willys Jeep.
Disclaimer
- THEORETICALLY, if you have an ABS-equipped vehicle, and you unplug the module and connect blue/black and blue cables, the ABS controller should receive exactly the same reading as before (it's the same blue cable, it gets the same nominal 13V current).
Page last edited on 19/09/2017 by user Bosanek
