Manual or fixed front wheel hub heads
Revision as of 07:42, 11 September 2017 by Bosanek (talk | contribs) (The introduction chapter and the chapter "Solution with manual hub heads" completely redesigned)
Vacuum operated wheel hub head on a wheel
  • Jimnys have pneumatically (vacuum) operated front wheel hub heads / caps.
Manually operated wheel hub head
  • The purpose of this article is to provide you an alternative solution to repairing that system - replacing it altogether with manually operated front wheel hub heads.
Note Icon.pngThe wiki article "Vacuum hubs - Checking and testing" contains all the general introduction about the purpose and operation of wheel hub heads, their operating systems, all the details about vacuum operated wheel hub heads, as well about related issues and repair solutions.
Note Icon.pngWheel hub heads / caps are usually just shortened in naming to "hubs", but a "hub" is actually an entire wheel hub assembly - the casing which contains the wheel bearing with its seals, the steering knuckle surround casing, the king pin bearings and (in the case of the Jimny) the pipes and passages which transport the air / vacuum through the wheel hub assembly to/from wheel hub heads.
Solution with manually operated hub heads
Reasons and advantages
Vacuum and manual wheel hub head for a comparison
  • However, there is luckily an alternative solution - to completely discard the vacuum system and vacuum front wheel hub heads, and install manually operated front wheel hub heads (like in Samurais and other classic 4WD vehicles).
  • Manually operated wheel hub heads generally have the lowest risk of failures, as there is by far the least amount of components which can fail.
  • The modification is relatively simple to perform, with required parts widely available on the second hand market and/or in the aftermarket.
  3. If you just want to preventively minimize the risk of a failure;
Disadvantages
  • As most manual hub heads have no anti-tamper mechanisms, a malicious person can easily (dis)engage a hub head while the vehicle is parked (easily remedied by the driver when detected, but can cause confusion while driving in the meantime).
  • If water enters into a manual hub head, it can freeze the manual (un)locking spring mechanism in the hub head during frigid weather. If this happens while the hub head is disengaged, it can prevent the vehicle from using 4WD transmission when it is needed the most.
  1. Removing the old vacuum operated hub heads and installing manually operated hub heads;
  • The first part is rather simple to do.
  • The second part is still simple if merely blocking is done.
  • The second part (removal choice) and the third part are a bit complex, and they differ for vehicles with manually operated transfer boxes and for vehicles with electrically operated transfer boxes.
Part 1: Installing manually operated hub heads
  • There are two solutions on how to achieve it.
Required parts for solution 1 (less expensive, more fiddling):
  • A pair of manually operated, second hand hub heads from a Suzuki SJ413 (Samurai) or from a Suzuki Vitara (Escudo / Sidekick / GeoTracker) Mk1.
  • Since the hub heads from earlier Suzuki vehicles do not fit directly on a Jimny, a pair of special spacers/adapters (with suitable bolts), which sit between these hub heads and the wheel hub assembly, is also required.
  • Browse the shops like BigJimny, JimnyBits, Bits4Vits, etc. for these spacers/adapters.
Note Icon.pngThere are numerous versions and editions of Suzuki SJ413s, Samurais and Vitaras in existence.
Required parts for solution 2 (more expensive, more elegant):
  • These are a direct "bolt-on" replacement - no spacers/adapters needed!
Note Icon.pngThe quality of aftermarket manual hub heads for Jimnys varies depending on a brand. There are even some no-name models around. You get what you pay for!
Required tools:
Reasons
  • After the first part of the conversion is complete, you will be able to manually (dis)engage the front wheels from/to the front drive line at will, but the 4WD controller will not function correctly.
  • Also, the vacuum system will be left "hanging in the air", doing its job in the void (literally).
  • It will still be possible to shift the transfer box into 4WD transmission mode just fine (since the operator is doing it personally with a mechanical lever).
  • Therefore, 2WD<->4WD (dis)engagement will work just fine. Just don't forget to manually engage the front wheel hub heads as well!
  • For non-ABS equipped vehicles, this is just a non-important visual inconvenience, which can be remedied (read further below).
  • For ABS-equipped vehicles, the operation of the ABS controller probably differs whether the vehicle is in 2WD or in 4WD mode.
  • In this case, it might be of vital importance to remedy the operation of the 4WD controller (and with it the 4WD light).
Situation with electrically (push-button) shifted transfer boxes
  • It will NOT be possible to shift into 4WD transmission mode, as the 4WD controller electromagnetically operates the (dis)engagement mechanisms in the transfer box after your push-button invocation.
  • The controller will refuse to perform the shift, because it detects a leak in the vacuum system (manual hub heads are not air-tight, and that's where the leak is).
  • When that is accomplished, the 4WD controller will work as before, including the operation of the green 4WD light on the dash board and also notifying the ABS system whenever a 2WD<->4WD change is made.
Solution 1 - blocking the vacuum system
  • The universal (and simpler) solution is just to block the vacuum pipes, so there will be no leaks in the vacuum system.
  • From then on, the vacuum system will report a successful vacuum formation every time when its operation is invoked, fooling the 4WD controller into thinking that everything is normal.
  • This means that even the green 4WD light on the dash board will function correctly, but it will have no meaning regarding the (dis)engagement of the front wheel hub heads. It will only indicate whether the transfer box has engaged the front drive line or not.
  • This solution works for any Jimny.
Note Icon.pngBy performing this solution in part 2 of the conversion, you have automatically accomplished part 3 of the conversion (fooling the 4WD controller) and your work is done!
  2. At the valves in the engine bey - disconnecting the pipes from the valves and then blocking both the pipes and the valves.
  • As far as it is currently known, blocking the vacuum system is the only practically feasible solution with electrically (push-button) controlled transfer boxes.
  • Reason - as the 4WD controller actually operates the mechanisms in the electric transfer box, it has to be fooled into thinking that the vacuum system is working. It must not be removed from the vehicle.
  • Other methods of fooling the 4WD controller could be faking some electrical inputs which it expects from the vacuum system. This has not been investigated yet in detail.
  • The disadvantage of this solution is that the vacuum valves and switches will still operate (in vain) every time when 2WD<->4WD mode is changed.
Solution 2 - discarding the entire vacuum system
  • With mechanically (lever) operated transfer boxes, the vacuum system can be discarded altogether.
  • Reason: The 4WD controller has no actual control over the mechanical transfer box, as it just operates the vacuum system and the 4WD light on the dash board (and possibly the ABS system!).
  • Therefore, after changing over to manual hub heads, the 4WD controller is left without anything to control (except the 4WD light on the dash board).
  • This is a more complicated solution for the "purists".
  • This solution also invokes the requirement to perform part 3 of the conversion process (read further down below).
  • Vacuum metering valve;
  • The check valve;
  • All vacuum pipes connecting the the engine, the valves, the tank and the wheel hub assemblies;
  • Don't forget to block the vacuum connection point on the engine itself!
Part 3: Removing the 4WD controller
  • After the vacuum system is completely removed, the last step is to remove the 4WD controller as well.
  • This will abolish operation of the green 4WD light on the dash board, but it can be brought back into regular service by connecting it directly to a switch in the transfer box.
Suzuki Jimny 4WD controller module (<'05)
4WD module location (in LHD vehicle)
  • Unplugging the coupler completely disables the vacuum system, as well as the 4WD light.
  • If you now start the engine and move the 4WD lever to 4H or 4L position, the transfer box will still engage the propeller shaft and/or the low range gear as usual, but you will have no indication of that on your dash board.
A coupler setup with 4WD light re-enabled after 4WD module removal
  • To re-enable the 4WD light on the dash board, you need to connect the blue/black cable (it comes from the switch on the transmission box) in the coupler with the blue one (it goes to 4WD light and the ABS module if equipped).
Disclaimer
  • Perhaps this is illegal in your country / area / religion / whatever.
  • THEORETICALLY, if you have an ABS-equipped vehicle, and you unplug the module and connect blue/black and blue cables, the ABS controller should receive exactly the same reading as before (it's the same blue cable, it gets the same nominal 13V current).
Page last edited on 11/09/2017 by user Bosanek
