King pin bearing change
Revision as of 19:03, 4 June 2016 by Mlines (talk | contribs)
Changing the Kingpin Bearings
Note Icon.pngPrint this page as a PDF
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement if they are worn, get an assistant to press the brakes, if it still wobbles then it is the Kingpin bearings.)
Leaking front swivel
Note Icon.pngClick on images to make them larger
Changing the bearings
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
removing a vacuum pipe
Removing the swivel seal bolts
Splitting the ball joint
undoing the Kingpin bolts
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!. That’s water pouring out of the axle! Also shown is a worn out bearing.
The rebuild
The old bearing race
Removing the bearing race
A simple way to drive them out is to use a 1" Imperial socket. Using an extension bar fed through the swivel place the 1" Socket behind the ring and drive it out by hitting it. (picture from Dave at Bits4Vits
The rebuilt swivel
The greased CV joint
Applying sealant
Page last edited on 4/06/2016 by user Mlines
