Fitting a Cabin/Pollen Filter
I wouldn’t mind betting that most people do not realise that the Jimny has a pollen filter or at least has the facility for a pollen filter. Most manuals never refer to it, even in the Service Guide.
I would also bet that most people, particularly those who drive off-road, are tired of the clouds of leaves that hit you in the face when you open the facia vents.
Fitting a pollen filter is straight forward once you know where it is hidden.
First you need a pollen filter [See the BigJimny Shop Filter
Also note that it is common to break the filter cover when removing it as the plastic becomes brittle, you may wish to consider buying a spare cover at the same time (See the BigJimny Shop Cover
Changing/Installing a Filter
Template:Warning!I cannot emphasis too strongly how easy it is to break the old cover!
Removing the Caliper and pads
Here is the filter cover, up underneath the dashboard on the passenger side of the vehicle
First remove the glovebox, this is done by flexing the sidewalls so the plastic retaining lugs can drop past the edge of the fascia. Lower the whole glovebox away. I am using a screwdriver with the end protected by a cloth to stop it marking the fascia as I use it to prise away the retaining lugs.
Removing the Brake Disc
Dismantling the Hub
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!.
That’s water pouring out of the axle! Also shown is a worn out bearing.
The rebuild
A simple way to drive them out is to use a 1" Imperial socket. Using an extension bar fed through the swivel place the 1" Socket behind the ring and drive it out by hitting it. (picture from Dave at Bits4Vits
Page last edited on 17/05/2016 by user Mlines
