Changing the Kingpin Bearings
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
* Standard metric sockets and spanners
* Assorted screwdrivers
* Circlip pliers (External)
* An E10 Torx socket for the Vacuum Hub Bolts
* A ball joint splitter
The Video
Removing the Caliper and pads
Removing the Brake Disc
