Revision as of 17:52, 12 May 2016 by Leftcase (talk | contribs) (→Front Clearance/Turn Signal/Side Turn Signal/ Rear combi/ Number Plate Light)
Headlights
| Application | Bulb Fitting |
| Dipped and Main Beam | H4 (472) |
| Side/Parking Lamp | W5W (501) |
| Front Fog Lamp | H3 (453) |
Fitting
Side/Parking Lamp
- Open the bonnet
 - The side lamp bulb holder is located at the outer edge of the headlight assembly
 - Twist the bulb holder one quarter turn anti-clockwise to remove. If this is difficult, you may find it easier to leave the cable connected as this will give you more purchase on the bulb holder.
 - Remove the bulb holder from the assembly and change the bulb.
Headlights
- Open the bonnet
 - Remove the socket and the rubber cover
 - Unhook the bulb holding spring and replace the bulb
- To remove, simply pull out or push in the bulb.
 - To remove a round bulb, push it in and turn it anticlockwise.
 - To remove a bulb holder from a light housing turn the bulb anticlockwise and pull it out.
