This article contains some important practical tips, notes and warnings when using and operating a Jimny.
They can ease your life, improve your experience or comfort, or save you from damaging the vehicle or even getting in a dangerous situation.
Some notes are common, i.e. non-vehicle specific, but are so important that they are still mentioned here.
Some notes are common for 4WD vehicles, while some notes are Jimny-specific.
Engaging and disengaging 4WD-H and 4WD-L
You probably know that you can (dis)engage between 2WD and 4WD-H on the move (and with the steering wheel pointing straight).
You might have also witnessed a loud "bang" from the front wheel vacuum locking hubs when disengaging, or even from a transfer case (that's already a serious bang!). A bang can be so strong that it is felt as a shock wave through the vehicle. A bang occurs when the transmission is disengaging under tension and this certainly wears it excessively.
Therefore, to minimize the risk of any mechanical damage or excessive wear, the best practice is to shift between 2WD and 4WD-H (and vice versa) while stationery.
Especially when you want to disengage from 4WD-H to 2WD, the best practice is to stop, then reverse a few meters back in a straight line. This releases any accumulated tension or wind-up in the transmission, which can occur often when part-time 4WD systems are active. Then disengage. You should rarely if ever get a "bang" this way.
Beware: If you (dis)engage between 2WD and 4WD-H while applying a significant throttle, a wheel slippage might occur during the shifting phase, and this is very bad for the transmission system (written in Jimny's Owner's manual).
When shifting from high range to low range and vice versa, make sure that the vehicle is completely stationary first! While it is technically possible for a skilled driver to shift while the vehicle is going rather slowly (you might have discovered that by a chance), you are taking a big gamble while doing so!
Using 4WD-H or 4WD-L on hard surfaces
Jimny has a part-time 4WD transmission system without a center differential.
- Dry tarmac roads;
- Dry grass;
Many people make a mistake of thinking that wet tarmac roads are slippery and turn on 4WD. Well they are slippery, but not nearly enough for Jimny's 4WD system.
Negotiating hairpin bends in 4WD modes
A "hairpin" bend/curve (also called a "switchback" bend/curve) is a very sharp road bend which changes the direction of the road by around 180 degrees. Such bends are common on forest and mountain roads. Also, many roads in forest/mountain junctions intersect at very sharp angles, especially on sloped terrain. Crossing from one such road to the other is essentially like going through a hairpin bend.
When you are going through a "hairpin" bend, and the transmission is in 4WD-H or 4WD-L mode, the transmission wind-up will be extreme. The reason is a small turning radius which hairpin bends have.
This is not so prominent if the surface is very slippery (boggy mud, icy snow, etc.). But if the surface is only slightly or "normally" slippery, it might not be enough to relieve the transmission wind-up which rapidly accumulates in such a tight turn.
- Warning: During this process, do not turn the steering wheel while stationery. Turn it only while in motion.
Using 2WD / 4WD-H / 4WD-L buttons
There is an annoying and potentially dangerous issue with all Jimnys which have electrically ("push-button") controlled transmission.
In practice, it is very easy to accidentally touch a 2WD or 4WD-H button when fiddling with the other nearby controls on the dashboard (primarily the lever for controlling if the air circulates inside the cabin or is drawn from the outside).
The result is that the vehicle will shift in/out of 4WD-H mode, without you even noticing it immediately in many situations. If it shifts into 4WD on a tarmac road, you might easily end with damaged transmission. This issue is particularly nasty on highways and on winding roads. If it shifts out of 4WD while going fast on a slippery dirt/snow road, you might end up in a ditch or in a canyon floor.
There is no known remedy for this issue, except that both the driver and the co-driver be very careful and aware of this.
The only consolation is that at least 4WD-L mode can not be engaged accidentally - the 4WD controller will refuse the command if the clutch pedal is not pressed.
Here is a video of the sequence on a 2005 VVT Jimny:
Driving properly
Do not drive the Jimny on the road as you would drive an ordinary passenger car. Many people are disappointed by Jimny's "bad" on road manners as opposed to the majority of modern cars. That is mostly because they have wrong expectations.
Drive the Jimny correctly and it might even be more entertaining than driving an ordinary vehicle.
In fact, many motoring journalists commented that Jimny is very entertaining and joyful to drive when they test-drove the Jimny in the early 2000s! Now the new generation X of journalists spit on the same vehicle, just because they don't know how to drive it.
Driving Jimny properly means that you should drive defensively, especially in bends. Drive smoothly and observe ahead, so you can timely adjust for changing conditions.
- Don't stomp on the throttle in a bend or when exiting it. Otherwise, you might get a free rollercoaster ride.
- Watch out for road undulations and slow down when you approach them. Otherwise, brace yourself.
- When reversing uphill, be easy on the throttle to avoid wheel spin. This is common with any Mercedes or BMW vehicle for example.
- If you see that you are driving too fast on a straight but imperfect road (the vehicle wobbles like a jelly or wants to fly off), then slow down damn it! It's an all-terrain vehicle, not a roadster!
If you drive the Jimny like an ordinary modern vehicle, the best case scenario is that your passengers will feel insecure and sick. The mid-case scenario is that you will spin out on a hairpin bend or in a roundabout. The worst case scenario is a rollover.
The way that idiot drove that Jimny in the video is actually how to drive a roadster-class vehicle on the road!
That wasn't even technically off-road terrain, as it is normal to encounter a tarmac road that is similarly potholed and undulated as that dirt road in the video.
If you like to drive like a "bat outta hell", then drive a batmobile.
Lending the vehicle
It is very dangerous to lend a Jimny to someone who is not trained to drive it. Read the chapter on proper driving for details why.
There are three risks:
The issue of lending is often overlooked. But the statistics are merciless.
For example, go to mobile.de German used car marketplace and search for all damaged Jimnys (there is a parameter "damaged vehicle" to select in advanced search options). You will see that about 50% of them have suffered a rollover.
Now, if you think about it, most of their owners had probably quickly learned how not to drive so stupidly to get even near to a rollover situation. So, most of those vehicles probably rolled over because someone else apart from the owner drove them!
Overloading the vehicle
Jimnys have unusually small weight carrying ability for a proper all-terrain vehicle. It is just around 300 kg in total. (someone needs to verify this)
The front axle can carry an additional X kg of load, while the rear axle can carry an additional Y kg of load.
This means that, with four adult passengers, you are already near the vehicle's maximum load carrying limit. And then come the bags, bicycles, tools and stuff!
So' beware when carrying heavy cargo like bricks, tiles, metal, obese people, gold bullions, stolen safes, etc.
Transporting four passengers
Jimny was made to transport four people at most, including the driver. There is no space to sit three people in the back, even if they are children or midgets.
However, there is space to fit three people in the back, but they won't fit as passengers, they will fit only as cargo would.
- Ventilation or air conditioning will be severely restricted, because there will be hardly any free space in the cabin for the air to circulate. Ever listened to the song "Steamy windows" by Tina Turner? Combine that with "I can't stand the rain" song from the same singer!
- Since everyone is tensioned up inside, if there is a very high risk of someone having to fart.
If someone farts in that situation, your interpersonal relationship will come to a similar end like this:
Forum user Bosanek indeed once transported four male adult passengers (with full mountaineering equipment) in his Jimny in an emergency situation for 80 kms, all on fine tarmac roads. Three adults were in the back with their equipment. How? Ever seen sardines in a can? That's how. However, the right rear spring sagged after that.
Page last edited on 9/02/2017 by user Bosanek
