- 1st gen. bumper (1998-2005)
- 2nd gen. bumper (2006-2012)
- 3rd gen. bumper (2013-ongoing)
- The 1st gen bumper is the smallest one (does not hang too low to the ground).
- The 3rd gen. bumper also is not bad.
- However, 2nd gen. bumper is overly large (hangs very low to the ground), and it significantly reduces the approach angle - the risk of it hitting the ground is quite higher than with other two bumper models.
1st gen. front bumper on a 2001 model year Jimny
The 2nd. gen front bumper is the most endangered point when off-roading, and it's easy to damage.
Also, 2nd gen. bumper reduces the space around the front wheels, limiting the size to which the wheels can be increased (by using larger tyres). With 2nd gen bumper, the usual limit is 205 / 75 / R15 (and even that size sometimes makes a contact if the bumper is sagged), while with the 1st gen bumper even 215 / 75 / R15 is not a problem.
For all the mentioned reasons, some people cut out (trim) the bottom half of the 2nd gen. front bumper, but it tends to look ugly. Also, if you trim a front bumper, you would lose your front fog lights (if you have them) and a place to hold the front license plate.
- Examples of trimmed 2nd gen. front bumper
License plate attached, but it hangs and could easily rip off.
License plate kept indoors. This might not be legal everywhere.
Side view on the result
Alternative solution is to replace 2nd gen. bumper with something else.
Solution 1: Factory bumper generation swap
If you have a 2nd gen. front bumper, and you find that it obstructs your vehicle's offroading "potency" (or limits your intentions on using larger tyres), the best alternative is to buy a second-hand 1st gen. front bumper (1998-2005) from a scrap yard, paint it if needed, and install it instead of the 2nd gen. front bumper.
You could even swap a 3rd gen. front bumper with a 1st gen. front bumper if you want some more clearance, but the difference is not so pronounced as with a change from 2nd gen. to 1st gen. front bumper.
The mounts for attaching a bumper on the vehicle should be (almost) 100% compatible on any Jimny from 1998 until today - but it has not been confirmed by someone yet.
- Here is a side-by-side comparison of 1st and 2nd gen. front bumper on the same vehicle.
- The "before" (left) part of the image is with a 2nd gen. bumper.
- The "after" (right) part of the image is with a 1st gen. bumper.
When purchasing a front bumper which is a different generation than yours, don't forget to also buy both (left and right) inner front wheel arches (black plastic arches). They have different length for different bumper generations - your current ones will either be too short with the new bumper, or you will have to shorten them (depending on what you are replacing with what).
Replacing one edition of a front bumper with another on the same vehicle should be legal (both are genuine parts), and it should not affect the operation of the airbag sensor(s). But this is a theoretical assumption.
Restrictions with DDiS Jimnys
If has been confirmed that replacing a 2nd gen front bumper with a 1st gen front bumper is not practical on DDiS (diesel) Jimnys with 63kW (intercooled) K9K engine.
The problem is that the engine intercooler sits low right up front, just above the right fog lamp.
If you try to replace the factory-installed 2nd gen bumper with the 1st gen bumper, you will have to discard the right fog lamp (if you have fog lamps).
You will also have to leave open the right fog lamp hole in the 1st gen bumper, in order to feed the intercooler with air (and even that hole might not be sufficient to feed it).
You should also install some grid in the right fog lamp hole, to prevent an object going through the hole and puncturing the intercooler.
Alternatively, you could dislocate the intercooler, but the free space in the engine bay is very scarce, and moving the intercooler is an expensive modification.
Solution 2: Heavy-duty metal "off roader" front bumper
Another alternative to all these factory bumper generation swaps or trimmings is to buy an aftermarket heavy-duty metal "off roader" front bumper.
- Prominent looks;
- Takes a beating off road;
- Typically increases approach angle;
- It can also be used as a mount for driving lights, winch, high lift jack, machine gun, a statue from the front of a ship, etc.
Page last edited on 3/02/2017 by user Bosanek
