4WD transmission failure diagnostics
Print this page as a PDF
File:Locking Hubs.png
Overview of locking hubs
  1. The vacuum makes the collar slide, but then is NOT required in order to hold the collar in position. Once the collar has slid in either direction it will stay there through the use of magnets and friction.
  2. The vacuum is used to make it slide both locked and unlocked by changing the route of the vacuum, removing the vacuum tube from a locked hub will not unlock it.
Principles
Note:
This guide was written based on a RHD (right hand drive) petrol Jimny configuration. The situation in LHD petrol Jimnys might differ in the positioning of some elements. The vacuum system in diesel (DDiS) Jimnys differs significantly in some aspects (see wiki article "Diesel (DDiS) Jimny specifics‎‎" for more information).
Location of Vacuum System
Vacuum Check Valve
Valve block
Vacuum Tank
Vacuum Tubes
Air filter
Lock tube (with brake caliper removed
Both lock and unlock tubes (black braided tubes) - the unlock tube is the lower tube that comes down to the front of the hub.
Vacuum Tubes
Fault finding
The table below shows the typical faults. Use the numeric references in the table e.g. (vi) to reference the specific checks in the following sections.
Status Problem
Fault Finding
4WD is selected on the transfer box
but the 4WD light is not on.
(i) 4WD Switch on transfer box has failed
(ii) the Switch wiring has broken
(iii) Fuse has gone
(iv) 4WD controller has failed
4WD is selected on the transfer box but the 4WD light flashes. The flashing is caused by the
4WD Controller thinking that the vacuum system has failed.
(v) Vacuum leaks from the system
(vi) Valve solenoid failure (VSV2)
(vii) Pressure switch failure
4WD is selected on the transfer box, 4WD light is on but
the front hubs do not seem to be locked OR hubs are locked and will not unlock.
(viii) Locking hub stuck
(ix) Vacuum pipes blocked
Checking the system
  1. Put the handbrake on, put the gearbox in Neutral, start the engine.
  3. Put the transfer box in 4WD, listen for a loud click from the hub and try and turn the car wheel by hand. If the wheel turns then it has not locked.
  4. If it has locked then move the transfer box out of 4WD, listen for a loud click and try and turn the wheel by hand. If the wheel turns then it has unlocked ok.
  5. Repeat for other front wheel.
Problem Area (i) – 4WD Switch has failed
Problem Area (ii) – Switch wiring has broken
Problem Area (iii) – Fuse has gone
Type 1/2 Fusebox – 4WD is FUSE 21
Type 3 Fusebox – 4WD is FUSE 38
Problem Area (iv) – 4WD controller has failed
  4. Air conditioning?
  5. 0 volts (earth)
  6. Vacuum switch –Open circuit or earth depending on Vacuum switch
  8. Air conditioning??
  9. Tachometer??
  10. 12 volts (from fuse)
Problem Area (v). - Vacuum leaks from the system Problem Area (vii). - Pressure switch failure Problem Area (ix). - Vacuum pipes blocked
Problem Area (vi) – Solenoid has failed
Page last edited on 29/01/2017 by user Mlines
