Template:Intro-note Template:Intro-note
- 1 Introduction
- 2 Changing the Clutch
- 3 Removing Interior Items
- 4 Draining the Oil
- 5 Removing Front Exhaust Section
- 6 Removing the Prop shafts, Transfer Box & Gearbox Remote Mechanism
- 7 Removing the Engine Mounting Bolts, Starter Motor and Clutch Cable
- 8 Separating Gearbox away From Engine
- 9 Replacing the Clutch
- 10 Refitting the Gearbox
Changing the Clutch
- Assorted screwdrivers
- Breaker bar
- Clutch alignment tool
- 10mm Square Drain plug socket
Centre Console
To remove the gearbox lever you have to remove the centre console. This is held on by four screws on the side at the front and back. The console then lifts out.
Mine was more of a problem as I have a switch panel fitted so I then needed to remove the gearlever before the console would come completely away, but this has to be done at some point anyway.
Gear levers
Lower Gaiter
Transfer Lever
Draining the Oil
On my Jimny the drain plugs are square and therefore a SQUARE 10MM drain plug socket should be used, however the square end of a 3/8 socket driver fits if you are pushed. Always undo the filler plug first because if the filler is stuck you do not want to drain the oil and not be able to fill it again. The gearbox filler is hidden up the side of the gearbox and lack of space is a problem
Exhaust
Lambda Sensor
Prop shafts
Transfer Box
Engine Mounting
Reversing Switch
Starter Motor
Clutch Cable
I originally purchased a cheap kit (CPK1086) from ebay, this was before the Bigjimny shop!. The quality seems ok (it is stamped as being made by AISIN – who supply Suzuki with parts), the only issue being that it was supplied with the incorrect release bearing. The company immediately shipped the correct bearing free of charge and assured me that the correct bearing should have been in the kit. Also note that the new plate has 4 springs whilst the old one has 3, again I have been assured that this is ok.
Note that you may want to fit extended breathers to the gearbox whilst it is in bits. The picture below shows the rubber pipe that is the normal breather (minus a plastic cap which has already fallen off!). The later models have an extended breather already, and it's another good candidate for slipping between the gearbox and engine while you are trying to refit it.
Page last edited on 24/01/2017 by user Bosanek
