BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
05 Jul 2020 19:27 - 05 Jul 2020 19:32 #224552 by lookonimages
A post to document & share a few enhancements over the next couple years. This Jimny is planned as a very long term vehicle.
Below is the wife with the new Jimny. She had the priviledge to go pick it up from the dealer.
Thank you for having me here and thank you for all other who have created inspiring build here and willing to share your knowledge.
Last edit: 05 Jul 2020 19:32 by lookonimages.
05 Jul 2020 19:38 #224555 by gv42
A JIMNY WELCOME FROM N/WALES UK
The following user(s) said Thank You: lookonimages
  • Lambert's Avatar
05 Jul 2020 19:54 #224558 by Lambert
Nice. I know what you mean about long-term ownership. My Dreadnought is 10 years old in January and I still think of her as a new car.
05 Jul 2020 20:20 - 05 Jul 2020 20:31 #224561 by lookonimages
First thing, she got proper rust protection spray. Even though we have a rather hot dry seasons without snow etc, we do live about 60km from the sea and often do visit.
I decided on a product called FluidFilm.
It is pure lanolin based.
"FLUID FILM® has been proved in some of the most severe conditions; Industrial, agricultural, raw-terrain construction – even on the space shuttle. Modified over time to adapt to environmental and application considerations, it’s non-toxic/non-hazardous.. FLUID FILM® continues to serve as the most effective corrosion control for industry, farming, industrial and transportation."
www.fluid-film.com/about/
I have the tools and bought the company's own spraygun withlong rubber/plastic tubes with propriety nosles etc..
Jimny is now fully undercoated. The long rubber /plastic tubes made it easy to spray inside cavities and chasis bars. The 360degree spray tips is just perfect spraying inside chanels / cavities.
Plan is to touch up anually.
Last edit: 05 Jul 2020 20:31 by lookonimages.
05 Jul 2020 20:46 #224564 by Soeley
Hello and welcome, looking forward to what mods you have in store.
07 Jul 2020 08:33 - 07 Jul 2020 08:40 #224625 by lookonimages
This is the first mod on the new Jimny.
Fixing the Beep warning tone when the key is in the ignition and a door is open.
I had a simmilar mod on my gen3 jimny. With my new Jimny gen4 it naturally went the same way.
Most people just silence it by disconnecting an electrical plug in the steering column as per Bigjimny wiki
I want it still to work, but be able to control it to switch it off when I want. So Idea is to add a switch in the line for the beep sound.
So I got myself a blank push button switch to use. Only to use two wires for on of switch function.
Here you can see I just used heat shrink wrap to close off two wires I will not need. Only using green & red wire that open close circuit.
Then I cut the pink wire of the connection that most people unplug.
I then soldered in the switch into the pink wire and use heat shrink wrap.
Taped everything nicely.
Plugged back in the ignition/door open electrical plug.
And here is the blank push button from where I control if beep is on/off when key is in ignition and door is open. I deliberately chose a blank button switch as i want it to be under the radar. Here the switch is on (pushed in).
Last edit: 07 Jul 2020 08:40 by lookonimages.
07 Jul 2020 08:45 #224626 by saxj
lookonimages wrote: This is the first mod on the new Jimny.
I'm also in SA (Jhb). Where did you get the switch from?
07 Jul 2020 09:25 - 07 Jul 2020 09:29 #224633 by lookonimages
4x4 direct Brackenfell cape town.
The package say "revo".
Also bought for spots and lightbar.
Absolute perfect fit
4x4direct.co.za/switches/8383-led-bar-li...for-toyota-revo.html
4x4direct.co.za/switches/8384-spotlight-...for-toyota-revo.html
4x4direct.co.za/switches/8385-blank-dash...d-other-toyotas.html
Last edit: 07 Jul 2020 09:29 by lookonimages.
07 Jul 2020 13:47 #224651 by saxj
lookonimages wrote: 4x4 direct Brackenfell cape town.
Thanks. I've bought stuff from them before. Decent service.
18 Jul 2020 07:03 - 18 Jul 2020 09:58 #225265 by lookonimages
Installed rear view camera. Working really nice.
The South African part numbers. SA seem not to use global part number
Last edit: 18 Jul 2020 09:58 by lookonimages.
12 Aug 2020 12:36 - 12 Aug 2020 12:44 #226559 by lookonimages
Added battery cables for second deep cycle battery in jimny for when going camping
Also added inline fuse as well as power disconnect switch
Off
On
Last edit: 12 Aug 2020 12:44 by lookonimages.
12 Aug 2020 12:46 #226560 by Soeley
That switch is neater than the key out type.
Time to create page: 0.272 seconds
Powered by Kunena Forum
