My Chiffon Ivory JB74 SZ5 - blog/mods/build thread
- Thank you received: 475
To me the Jimny is a car that encourages a more relaxed driving style, enjoy the scenery instead of whizzing past.
Snap, I have the same model and colour. Reading this thread could cost me quite a bit in mods...
Are you considering a snorkel?
- Thank you received: 168
Today's job was to fit some diff guards from Jimnybits. These were kindly bought for me as a birthday present recently
Rear guard, looks simple enough to fit:
Up on some ramps for better access:
It fixes via two bolts on the diff to diff housing, then a U bolt over the axle tube at each end. Nothing more than a 12mm sock, extension and deep 17mm socket required. One of the easiest off road mods I've performed:
All done
Now onto the front diff. Sadly no instructions were included with the guards, although once ushered up, they are fairly obvious how they fit.
The front guard is of distinctly different design. No bolts included part from a single U bolt. Looking at the front diff, you can see the bracket for the front radius arm as some studs that the bolt passes through. The guard is designed to hang onto those.
Only one radius arm bolt need undoing, just enough to move the threads inside the stud, then the guard slipped up and into place.
Tighten the U bolt and job jobbed!
Jimny vs Jeep:
I'm undecided on a snorkel. As tbh I probably won't do any water wading to justify it. I know they kind of look cool, but are also a tad bulky and for me are on the wrong side of the car, being the drivers side.treps wrote: Great review, thank you.
And while I have no problems cutting holes in my 1970's Land Rover (which has an aluminium body). I'm a little more hesitant on a brand new vehicle with a steel body.
So if I do get one, it will be way down the list for me.
- Thank you received: 34
You can just about see how much mud is on the front recovery point in this shot:
Soeley wrote: What size are those tyres?
215/75R15
- Grima
- Visitor
Yes they look well bigger but there not.
Simple look at the width not the height.
I can't find published data for either tyre for their exact height or diameter, however I would say they certainly look more than 10mm taller.
