Soeley's 2019 Black SZ5
- Thank you received: 478
My full set of sun/privacy window blinds arrived from Japan. Black on one side foil effect silver on the other. Some light still gets through but for car camping I thing it would be OK once dusk arrives.
All packs up pretty small and weighs nothing.
Silver side on the inside, I didn't use all the suckers for a quick trial fit.
This is the black side facing out.
Black side facing out.
Silver side facing out.
Thinking cap on again.......
A good fit around the edges without any light showing.
Tie backs with magnets and washers to fasten together.
The end is folded over and stitched in the middle to create a flap that wedges inside the roof lining.
Easy to fit and remove if need be.
Rolled up blind, I just need to trim the straps to length now, but will drive round for a few days to make sure they stay put.
Barely visible from outside as well.
So those have been in place since October 2019. They roll down and back up very easily and they are always there. I did something similar for the rear window. The front sides needed a different approach as there is not enough overlap to use magnets.
I will update on the rest shortly.
Soeley wrote: Rear Door Internal Release.
It works! It is a little stiff, but it will only be used when I camp out and sleep in the car (or in emergency )
I will cover the exposed cable in black shrink sleeve and will come up with some sort of handle/lever to attach it to
Found out why the video isn't playing, I used the wrong tagging option
Here goes
- Thank you received: 1761
- Thank you received: 34
Handle, mounting bracket and reinforcing back plate
Handle/lever
Mounting bracket bolted to trim panel.
Reinforcing plate on the back.
With cargo nets refitted not too much to see.
All assembled.
Slight oversight, rubber mat needs either tucking under or just lifting to operate the handle.
