My Jimny named R&B
A friend did mine for me in South Essex.
- Thank you received: 650
Paint my swivel's
Trailgear shafts n cv's
26 spline side gears
And new kingpin bearings if needed
Modified landy engine mounts to fit transfer cradle
Measurements
X2 cut to fit driver side
This one cut and shaped to fit Redacted cradle
Not sure you would need to modify for standard transfer mounts
While i was under their had a look at rear engine mount
Central bolt looked off to oneside
So got a new one from the spares shelf
Old one not delaminated but rubber really soft
Got fed up of the bolt through one's moving to one side slightly. think that's due to the bolt through's only being M8
Landy one's are M10 so no movement to be had,the transfer is lifted around 15mm higher up now
Expecting some vibration from them....but knowing they are now super strong i can live with vibration
jackonlyjack wrote: They do fit well Riccy
Does your transfer box not hit the floor of the Jimny? Do you have a body lift?
Also it drives/feels better than with the bolt through's on
No noticeable vibrations
I might consider doing a 1" body lift just to enable me to do this at some distant point in the future.
I'll likely get a normal car next year for daily duties, so it won't be as necessary but I will have more time to do it.
Well done for working this out. I for one am grateful.
These have a +et of 33
So when adaptors are fitted it will leave me at
+3 et/offset
- Thank you received: 1754
