BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
My Jimny named R&B
  • OlaGB
  • Visitor
  • Visitor
04 Dec 2018 14:07 #198619 by OlaGB
Replied by OlaGB on topic door card modification
jackonlyjack wrote: got fed up banging my elbow problem sorted ;)
Jack
Really good idea..! Sick of banging my elbow into it as well, might copy that idea!
You used metal plates? Where you able to make them without any sharp edges? Easy to cut holes in expensive clothes.
04 Dec 2018 14:59 #198620 by jackonlyjack
04 Dec 2018 17:31 #198637 by Max Headroom
Replied by Max Headroom on topic door card modification
Great idea.
....you could always glue some leatherette trim over them
26 Dec 2018 14:42 #199462 by jackonlyjack
Replied by jackonlyjack on topic New props
Just fitted new front/rear props
Doing my first ever RTV event 6th Jan
Jack
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
26 Dec 2018 16:37 - 26 Dec 2018 16:38 #199466 by Riccy
Replied by Riccy on topic New props
B) Nice and sturdy.
RTV = Road Trim Vehicle? NL4x4 has that class and it means = something which could pass an MOT (just). expect a risk of going on your lid :laugh:
Last edit: 26 Dec 2018 16:38 by Riccy.
26 Dec 2018 16:55 #199467 by jackonlyjack
Road taxed vehicle class should be a breeze nothing to demanding according to organiser
Maybe 2020 will enter CCV custom class vehicle but will need roll cage and a lot more demanding
  • Daniel30
  • Visitor
  • Visitor
27 Dec 2018 16:50 #199497 by Daniel30
Replied by Daniel30 on topic New props
Good luck
25 Jan 2019 20:40 #201705 by Dirtbird
Replied by Dirtbird on topic MOT day
jackonlyjack wrote: After wifey got me a dash cam for my birthday
Had to make few modifications as I can't be doing with anything stuck to windscreen
Also a new interior light nice and bright
Happy with the new additions :)
Jack how did you fit the interior light to the headliner and did you wire it into the courtesy light under the rear view mirror? Im king of following your work Jack or kind of on the same wave length I seem to be thinking the same way about the same things .
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
26 Jan 2019 09:42 - 26 Jan 2019 10:00 #201725 by jackonlyjack
Replied by jackonlyjack on topic Interior light
The lamp is a ring one same as my reverse light
I cut a square hole half inch sized used a flexible tent pole pushed it towards where the old light was
then tapped wires to thin steel rod pushed it along side to get wires through
connected to connector for old light (just be aware it only operates with door open)
The back of light is nice and flat so i used hook side of some velcro glued to light
pressed it to roof liner and it's never moved since ;)
Best thing i've done it's so bright :)
Jack
Last edit: 26 Jan 2019 10:00 by jackonlyjack.
27 Jan 2019 22:20 #201889 by Dirtbird
Replied by Dirtbird on topic Interior light
jackonlyjack wrote: The lamp is a ring one same as my reverse light
Jack
Going to do this mod think its a good option, the door will always be open to get gear out.
28 Jan 2019 08:18 #201901 by Max Headroom
Replied by Max Headroom on topic Interior light
jackonlyjack wrote: The back of light is nice and flat so i used hook side of some velcro glued to light
Velcro is great for a semi-permanent attatchment of lightweight items. I've used Velcro extensively on internal trim panels on executive jets. The only weak-link is the glue attaching it, which could eventually fail particularly when it gets very old and spent lots of time in very hot climates.
Great write up
28 Jan 2019 16:25 #201924 by jackonlyjack
I like velcro a little to much :pinch:
My other like is 3M acrylic foam tape this is how the rear fog and reverse lights are held on :)
Jack
Time to create page: 0.237 seconds
Powered by Kunena Forum
