Kirkynut's Jimny (aka Daddy's Tractor) - The Evolution continues...
RainerK wrote: Be carful and watch this tire. The carcasses might have been damaged and also over time might get moisture inside. Because it is a rear tire it might br not so bad if it fails.
Nah, it was a very thin one and got bent at 90' so it kind of went sideways into the surface and a block of tread. It really wasn't in deep enough to bother the carcass but you don't know that until you pull the buggers out!
Thank you though.
- Thank you received: 1759
Lambert wrote: there's something about the side profile of the gen3, it just looks right. (Even if it is drawn in a conceptual art kinda way!)
Conceptual art! Thank you for being so polite about my crappy drawing that most likely, only I like!
- Thank you received: 475
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
You will be back.
- Thank you received: 332
I go with Lambert.
You will be back.
The shell is very rotten and the chassis is cracked. The guy who's taken it is a scrap man and an off roader. The chassis will be recycled into something else and the shell will be truck cabbed and welded up before being put on a Disco 300 tdi chassis as the Disco had rolled. It will live on as purely an off road monster at my local club!
I've sold the engine, gearbox, external cage, Rocklobster, axles, all my spares etc.
I have the half leather interior, wheels and tyres and some bits and pieces that will likely sell easily and are small enough to post left, which I'll sort out next set of rest days and list in the For Sale section here first.
Then I'll use the money I've got from breaking the Jimny towards a bigger 4x4 that is big enough for our family, which is looking Disco 2 shaped at the moment.
I've always lusted after a Disco and now is the time. I've had the Jimny a very long time and now it's time to move on.
I'll pop in here and keep an eye on Lambert every now and then I'm sure!
