Forum
Suzuki Jimny
Jimny Technical
Stiffer springs than stock = better???
BigJimnyMeet 2024
Thank you received: 176
03 Mar 2023 16:51 #247868
by gv42
Apparently in Japan, you can get a 3rd party arb
Sent from my 2201116SG using Tapatalk
Thank you received: 738
04 Mar 2023 14:33 #247888
by Busta
Just a front ARB on a JImny. Be aware that fitting a stiffer front ARB will increase the cars tendancy to understeer.
As others have said, valve springs alone won't help with anything. To get more power at higher rpm you will need more aggressive cams. There's no point changing the valve springs until you have some cams to fit and a programmable ECU to tune the engine accordingly. But you have previously mentioned you are going to be fitting a bigger engine anyway, so put the parts into that rather than the 1.3.
Forum
Suzuki Jimny
Jimny Technical
Time to create page: 0.086 seconds
