BigJimnyMeet 2024
Fuel line fittings for fuel tank
28 Jan 2023 18:42 #247239
by hJohn
Fuel line fittings for fuel tank was created by hJohn
Hello,
My fuel lines started leaking - from above the tank. So now I have dropped the tank and removed the fuel lines but they use a special fitting that I do not know the name of.
Does anyone know what the fittings are called? Can I remake new lines with the current fittings, buy just new fittings or do I have to order completely new lines?
- Roger Fairclough
- Thank you received: 194
28 Jan 2023 21:38 #247243
by Roger Fairclough
Replied by Roger Fairclough on topic Fuel line fittings for fuel tank
pics. of the pipes would be helpful.
Roger
Roger
29 Jan 2023 08:46 - 29 Jan 2023 08:59 #247246
by hJohn
Replied by hJohn on topic Fuel line fittings for fuel tank
Which pipes after you referring to?
Are you able to see the pictures I attached? I am trying to replacing all of the lines going from the fuel tank.
Edit: I am talking about part 8 & 9 from this exploded view here partsouq.com/en/catalog/genuine/unit?c=S...id=1624&uid=63649&q=
Part numbers are 15820-81A02 and 15860-81A02.
Last edit: 29 Jan 2023 08:59 by hJohn.
29 Jan 2023 09:04 #247249
by hJohn
Replied by hJohn on topic Re:Fuel line fittings for fuel tank
Does that kit include both the fuel line and the return line? And does it go the full length to the engine?
- Thank you received: 178
29 Jan 2023 09:28 #247250
by gv42
Replied by gv42 on topic Re:Re:Fuel line fittings for fuel tank
It's a kit we got, came with 2 lines , both different diameters, long enough to reach the rail, in engine bay, didn't come with vent pipe, I don't think the retailer has the dual kit left, but will get you details of the bits and bobs, as it's all off the shelf items from what we can see, will find out the details in the week?
Sent from my 2201116SG using Tapatalk
- Roger Fairclough
29 Jan 2023 09:54 #247251
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Fuel line fittings for fuel tank
These bayonet style fittings may be to a basic fuel line spec. Search for "Movkzacv fuel line quick release coupler". I found the info. on Amazon. Data sheet gives dimensions so you can check with the tank fittings. About £8 each.
Roger
Roger
29 Jan 2023 16:48 - 29 Jan 2023 16:49 #247257
by hJohn
No eBay APP ID and/or Cert ID defined in Kunena configurationI went ahead and ordered the kit after talking to the seller on eBay. Listing # 295380722505
Last edit: 29 Jan 2023 16:49 by hJohn.
17 Feb 2023 11:57 #247653
by hJohn
Replied by hJohn on topic Re:Re:Fuel line fittings for fuel tank
My order has still not shipped.
@gv42 could you check the parts so that maybe I could make it myself?
17 Feb 2023 15:48 #247654
by gv42
Replied by gv42 on topic Re:Re:Re:Fuel line fittings for fuel tank
23 Feb 2023 07:16 #247719
by hJohn
Replied by hJohn on topic Re:Re:Re:Fuel line fittings for fuel tank
No worries. eBay won't let me cancel the order until the 28th anyway so it might ship (probably not).
But I would appreciate if you could post your findings when you make your own kit.
25 Feb 2023 06:43 #247746
by gv42
Replied by gv42 on topic Re:Re:Re:Re:Fuel line fittings for fuel tank
Some possible correct tank connections coming today in the post, will advise if they fit, first step really making a full kit
25 Feb 2023 18:14 #247757
by gv42
Got these off Amazon and they fit the tank , details later for the fuel lines, I do know you need about 3.5 meters each , so buy 4 meters of each , both are different sizes, also need a vent pipe, details later ( some of the information was gleaned from someone on here , thank you )
