Overheating
- Thank you received: 1
06 Jul 2022 17:06 #243963
by tomlil01
Overheating was created by tomlil01
Hi, all,
Hoping someone might be able to advise me on a problem.
A few times when I was off-roading I noticed that my water temp guage had gone into the red. When this happened, I stopped the car immediately and left it for for 10/15 minutes and the temp went back to normal and then stayed normal. This only happened about 3 times over the course of several months. Generally the temp guage would sat a little under half-way. I never had steam coming out of the radiator, and coolant seemed to remain on max.
Now, this week the car started overheating on the motorway, and I stopped the car and found that the coolant bottle was empty and I could see some coolant was leaking (visible at the bottom of the radiator).
I am obviously going to replace the radiator, but I am wondering whether I have an additional problem? Obviously, the car will overheat with the leaking radiator, but I don't know why I was getting these "sporadic" occastions when it was overheating before, and then seeming ok for weeks or months? Would this just be radiator getting blocked up as it deteriorated, or might there be a problem with some valve or sensor that controls the water flow or something? (sorry, I am not very mechanical, so don't know how the cooling system works).
Any advice very much appreciated.
Cheers,
Lee
Cheers,
Lee
- Thank you received: 1714
06 Jul 2022 19:21 #243966
ADOS Attention Defect Ooooh Shiny!
Replied by Lambert on topic Overheating
Contrary to what some people may want you to believe if an m13a Jimny engine over heats as your one has it will need a new head gasket. Yes by all means replace the radiator especially if it's leaking and even the rest of the cooling system but ultimately none of that will permanently solve the issue. I speak from experience of having attempted to nurse a Jimny with your symptoms of periodically over heating and it was expensive just replacing various parts that didn't fix the problem and then having to do the gasket anyway.
06 Jul 2022 19:33 #243969
by tomlil01
Replied by tomlil01 on topic Overheating
Thanks for the info, Lambert. Would there not be other symptoms if it was the head gasket, like white smoke from the exhaust or something?
- Motleycrew
- Elite Member
- Thank you received: 23
06 Jul 2022 19:38 #243970
by Motleycrew
Replied by Motleycrew on topic Overheating
I would follow Lamberts advice. The coolant is probably being forced out of the hose joins of the cooling system ,as it is getting pressurized from the gasket being failed. This also air locks the system so water will not be circulating. One way to determine is wait for the engine to cool fully and then open the radiator cap. If it hisses you know that air is being forced in on the compression stroke on the engine. I had the same issue for ages and it just gets worse.
- Motleycrew
- Elite Member
06 Jul 2022 19:43 #243971
by Motleycrew
you get a push and pull action on the oil and water. Intake stroke (sucking) will draw oil and water into the combustion stroke producing blue/white smoke. combustion stroke (push) will force exhaust gas into the oil and cooling system.
06 Jul 2022 19:45 #243972
It's often the case as stated above that the failure is across the cylinder to water jacket and over pressurises the coolant more than contamination of the oil.
06 Jul 2022 19:58 #243973
by tomlil01
Thanks for the info. I will try this test with radiator cap tomorrow.
So, if there is no hiss then there is no reason to think a head gasket problem?
- Thank you received: 527
06 Jul 2022 20:36 #243974
by Scimike
Replied by Scimike on topic Overheating
It's all been said, it's possible it's a head gasket leak to a cylinder.
You could also take the plugs out, they should all look the same colour etc. An overly different one (usually cleaner) is the cylinder into which the coolant may be heading. Another indicator is momentarily running on 3 cylinders for a few seconds first start of the day, but usually ok after this for the rest.
Just some things that may help.
09 Jul 2022 10:42 #244017
by tomlil01
I did the test of getting the car up to temp and then letting it cool a bit and opening the radiator cap. There was no hissing sound, so I assume that indicates there is no issue with the head gasket (necessarily)?
09 Jul 2022 10:43 #244019
by tomlil01
Also, no smoke from the exhaust. Oil looks normal on the dipstick. No evidence of oil in the coolant
- Motleycrew
- Elite Member
09 Jul 2022 18:53 #244023
by Motleycrew
sounds promising, perhaps it was a coolant leak. If you find it overheating and you cant stop, put the cabin heater on full and blower on full. You can dump a huge amount of heat that way and the temperature should reduce quickly.
09 Jul 2022 19:31 - 09 Jul 2022 19:45 #244024
by Scimike
The only real way to check is to pressure test the cooling system. It's not a complex process, in simply terms replace the radiator cap with a bung and use a pump to pressurise the system to a few PSI, wait a few hours and check the pressure is the same. If it's not you have a leak and need to find it.
You can make something (see YouTube) or purchase a tester for about £50, or get a garage to a test for you.
You say you have a leak from the bottom of the radiator, it's possible it's the radiator or top hose, both will drip randomly from the radiator bottom, so check the source of the leak or just replace both.
Even after this a pressure test is the only conclusive way of checking for leaks and that no other issues are present across the complete system.
Last edit: 09 Jul 2022 19:45 by Scimike.
