BigJimnyMeet 2024
Spark plug choices?!
- Thank you received: 551
12 Nov 2021 00:51 - 12 Nov 2021 01:04 #240039
by Scimike
Replied by Scimike on topic Spark plug choices?!
I have fitted a few makes all listed as compatible. Bosch, nickel and iridium NGK, Beru.
The common factors have been they all worked fine and offered no noticeable difference in MPG or performance.
As stated the only difference is expected plug life. The nickel plugs are rated for 10k miles, although they can last longer. The NGK Iridium plugs are rated for 40k plus life. I am currently using a set of NGK Iridium plugs to see if they live up to the claim, so can't confirm at the moment.
The Beru plugs I used are only good for about 15k miles, so not much better than the nickel plugs.
Iridium is ideal for vehicles with hard to reach plugs as there cost is offset by the labour cost to change them. This is not really an issue on a Jimny, if you service yourself every year and cover less than 10K then nickel plugs are fine. Higher milage or just a dislike of changing them makes Iridium the better choice.
Last edit: 12 Nov 2021 01:04 by Scimike.
- Thank you received: 1755
12 Nov 2021 06:03 #240040
Replied by Lambert on topic Spark plug choices?!
This is why I use them. In conjunction with my k&n panel air filter and an average of a thousand miles a month it reduces my service time for intermediate services to just an oil and filter change every 9 months. The air filter has paid for itself many times over as its washable every 100k, the plugs save time and wear and tear as I'm only disturbing them every 3 years. That said I suspect even then they would probably go longer as they are always perfect when I replace them, but I don't want to risk that as you can go too far and it becomes neglect.
12 Nov 2021 17:34 #240048
by Waffs1984
Replied by Waffs1984 on topic Spark plug choices?!
Great, thanks all - useful advise. I've got the filter to collect from ECP so will stuck an order in for some NGK cheap plugs just now as I have no idea when the car was last serviced.
Any ideas on my engine code from previous post? I did a bit more reading and believed the way to tell if vvt is the bump at the front left of engine as you look at it, which I don't have, so assuming it's a non vvt m13?
12 Nov 2021 20:00 #240054
by Scimike
You are correct, you are missing the VVT bump.
The following user(s) said Thank You: Waffs1984
13 Nov 2021 09:48 #240062
by Waffs1984
OK, got me some NGK BKR6E plugs, came up on ECP under my reg and cheapest at £2.98 before discount. Guess I should double check plug gaps even though most stuff I've done in the past 20years has come pre gapped - anyone know what they should be?
14 Nov 2021 16:57 #240116
by Waffs1984
No matter, services it today and just chucked the plugs in, all running fine. Easiest car to service I've worked on in a while! Filter and drain plugs are in a really handy location, small plastic takeout box to catch oil from filter job done.
- Thank you received: 359
14 Nov 2021 19:14 #240124
2020 blue SZ5
Replied by DrRobin on topic Spark plug choices?!
Most plug gaps are pretty much spot on these days, the vehicle manufacturer pretty much goes with the plug manufacturer's standard gap.
Just as well as on my other car the plugs have 3 cathodes arranged around the central anode, I wouldn't want to start trying to gap those, I don't think you would ever get them all the same.
2020 blue SZ5
10 Nov 2023 02:27 - 10 Nov 2023 02:29 #252045
by Miownway
2022 JB74
K15B w/ snorkel
XTREME OUTBACK stage 1 clutch
Warn VRX 4500 winch
235/75R15
Replied by Miownway on topic Spark plug choices?!
I have read that NGK has an upgraded spark plug from the Premium RX to the Ruthenium HX. I can not find a cross-reference between the two. The specs for the Premium RX (DCPR6ERX-11P / 90558) are: Thread diameter: 12mm Thread reach: 19mm Seat type: flat Hex size: 16mm
Is there a Ruthenium HX model that matches this spec?
Or, am I way off with my understanding about these?
2022 JB74
K15B w/ snorkel
Warn VRX 4500 winch
235/75R15
Last edit: 10 Nov 2023 02:29 by Miownway. Reason: Format
- rogerzilla
- Thank you received: 57
10 Nov 2023 09:26 - 10 Nov 2023 09:28 #252052
by rogerzilla
Replied by rogerzilla on topic Spark plug choices?!
I fitted the Denso iridium ones. A bit cheaper than NGK and I found a marginal improvement in mpg with them in other cars.
I don't know if Denso supply Suzuki but they supply a lot of OEM parts on Mazdas etc.
Last edit: 10 Nov 2023 09:28 by rogerzilla.
10 Nov 2023 15:38 #252058
2020 blue SZ5
In 2021 I bought a set of NGK Iridium IFR6J11, 4 for £52 for my 2011 Gen3. I fully expect them to last the life of the car, but if they do need replacing it won't be the tip that has worn out, it will probably be oil fouling or some other type of damage.
Iridium are meant to be good for up to 100k miles.
Ruthenium tip are meant to last longer and give slightly higher performance, whilst this might be true of a modern car engine where fuel efficiency and performance is much higher I doubt it will make any difference at all to a Jimny.
The longer electrode life will be of limited benefit as something else will wreck the plugs, like oil fouling, over-heating or muck and dust on the outside so I doubt you will see any benefit.
However, see how much they are and if they are about the same price as Iridium (or cheaper) then go for it, just don't expect to notice any difference over a decent set of ordinary or Iridium plugs.
By the way I couldn't find any for sale in the UK to fit a Jimny, there seemed to be some in Japan though.
Robin
Robin
2020 blue SZ5
10 Nov 2023 16:06 #252060
by Busta
Replied by Busta on topic Spark plug choices?!
Don't overthink spark plugs. All Jimnys have very basic, low performance engines. The only benefit of more expensive plugs is lifespan, but that is reflected directly in the cost. And if you don't change your plugs for a decade, you may find them reluctant to come out which can lead to much bigger issues. I use standard copper plugs in my Jimnys. They are £20 a set and look good as new after 2 years/20,000 miles.
Time to create page: 0.159 seconds
