BigJimnyMeet 2024
First issues with ownership.
- Sean65
- Visitor
18 Aug 2021 18:08 #237698
by Sean65
First issues with ownership. was created by Sean65
Hi all. Having driven the 02 Jimny back last night with no indicator first job new bulb. Hmm. Bulb or bulb holder. Power lead floating around near the housing. Or so I thought. Off to motor factors. Not a push in like the lead suggests. Chap said amber bayonet fit. First mystery. Photo attached.
Next off to check 4x4 and Low range. Mine is not a switch but the lever. 4wd. Seemed to engage according to the green light on the dash. Press down for Low. Hmm. No obvious change I was expecting it to be like my 90. Is there supposed to be an indication light on dash for low. How can I definitely check? Beginning to think i may have bought a pig in a poke.
Any help for a still enthusiastic new owner please. . For now.
cheers
cheers
- Thank you received: 71
18 Aug 2021 19:32 - 18 Aug 2021 20:06 #237699
by lightning
Replied by lightning on topic First issues with ownership.
Low range is definitely evident when driving, but doesn't have the same feel as a Defender, where you can be in low range fifth gear at 20mph and doing quite high RPM
A twenty year old Jimny is going to require some love, in the same way that a twenty year old Defender will.
Every Defender l've bought has needed at least one fairly major expense after purchasing.
Last edit: 18 Aug 2021 20:06 by lightning.
- Thank you received: 77
19 Aug 2021 00:58 #237706
by fordem
Surely there's a matching bulb/bulb holder on the other side - remove it and use it as a specimen.
Replied by fordem on topic First issues with ownership.
- Sean65
- Visitor
19 Aug 2021 06:35 #237709
by Sean65
Replied by Sean65 on topic First issues with ownership.
Thanks. This was my next option but thought i would query seeing as motor factors didn’t have anything other than bayonet fit listed. Test lamp option to see if it flashes perhaps. .
Major expense. Apart from needing a new chassis. My 90 has been great. Maybe I need a longer play with the low range. Is there s dash light to give me some idea.
19 Aug 2021 07:45 #237710
by Busta
Replied by Busta on topic First issues with ownership.
Low range is down and back. There is no light on the dash. You should notice as soon as you pull away that 1st gear is lower.
- Sean65
- Visitor
19 Aug 2021 11:11 #237711
by Sean65
Thst’s shat I thought but there seems no obvious change .
19 Aug 2021 12:04 #237712
by lightning
Similar to a Land Rover, it's probably never been used and is siezed or jammed.
19 Aug 2021 12:05 #237713
by Busta
I've never heard of low range not working but I have known people to have trouble selecting it. The pattern is on top of the lever. Shift back for 4wd, then press down and shift back further for low.
It can also be hard to select if the vehicle has had a body lift fitted. In this case the gear stick fouls the body and needs to be bent, or the hole in the floor trimmed.
- Sean65
- Visitor
19 Aug 2021 14:02 #237714
by Sean65
My 90 has definitely been used although i did have to play with that as previous owners certainly hadn’t been beyond a grassy car park. The instructions on the lever are clear enough snd I had wondered if it was a consequence of raising.
When i stop driving around picking up stuff my wife keeps buying on Marketplace. I will have a proper look. Lol
- Sean65
- Visitor
25 Aug 2021 09:31 #237857
by Sean65
I have ust been away for a few days and have just taken some photos whilst the chap was swapping my tyres over. Perhaps some could advise what lift does it appear I have and also what is going on with the non symmetrical rear shock lower mounts. The don't look right at all, or is it just some odd peculiarity of it being raised which I doubt.
25 Aug 2021 14:33 #237861
by Busta
There's some dubious looking DIY action going on there! Spring spacers on the front, rotted out front body mount but no body lift and looks like they have tried to make rear shock spacers but didn't understand the significance of having the pivots at 180 degrees to each other.
- Roger Fairclough
- Thank you received: 194
25 Aug 2021 17:16 #237866
by Roger Fairclough
Replied by Roger Fairclough on topic First issues with ownership.
The spring does not appear to be correctly located at the bottom. Spring spacers obviously (badly) home made. The home made rear shock mounts have 1 bolt to locate instead of a minimum 2 and it has loosened and the mount has swiveled.
Roger
Roger
Time to create page: 0.199 seconds
