Body lift
- Thank you received: 49
I've been spending today cleaning and reconnecting electrical harness connections in the engine bay, but there's one plug, just under where the battery tray goes that's left.
Does anyone know what this one plugs into or where it should go?
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
- Thank you received: 1755
I don't think it's redundant as I checked the contacts and they look quite clean, as does the sealed portion of the plug.
I should have added that I have an M13 engine as it's a 2007 Jimny.
I did think it might be something to do with the A/C system, but it's the wrong side of the engine for that.
- Thank you received: 923
Easier to see with no inner wings!
Single wire from this goes off to the power steering pump top...?
Its the one you bridge the pins to fool the 4x4 ecu into thinking the vac hubs are working when fitting manual hubs
Hi Riccy,I did think that but the vac hub solenoid is plugged in. This connector is not far from the bulkhead. Actually, the loom that comes through the bulkhead is where it's located, just as it goes under the battery tray, just before the vac solenoid area. It doesn't have much slack on it, so I'm puzzled as to what connects to it. You can see in the pics that the mystery connector is just under the leg of the fusebox and the solenoid connector is connected (each pic is a different connector for clarity). I'm stumped as I can't remember disconnecting it.Riccy wrote: Looks like the plug for the vac hub solenoid, which is located on the wing below the battery.Its the one you bridge the pins to fool the 4x4 ecu into thinking the vac hubs are working when fitting manual hubs
- Thank you received: 551
And one at the rear under battery box near servo.
Any help? Can look again when it's light.
Looks like the second one near the servo to me. If you know where that's connected, that would help me greatly. No rush tho. I'm inside now with a cup of teaAnd one at the rear under battery box near servo.
If no one goes "ta dah" with the answer between now and tomorrow evening I will take a better look for you.
Mike
