BigJimnyMeet 2024
Re:Re:Re:Re:Re:Transfer case info
- Thank you received: 36
10 Mar 2021 09:59 #233602
by Old Neil
Cheers Neil
Replied by Old Neil on topic Re:Re:Re:Re:Transfer case info
Dave that is exactly the info i was looking for is there a way of finding the part numbers of the low raitio gears, see if i can buy them new do you know if i can fit them to my original transfer caseX8GGY wrote: Hi, No...
The auto transfer box has the same high ratio side, and the low side is lower as you originally thought...
BUT it is a switched model, not a stick shift one...
I'm trying to find out whether the gears inside would be transferable from the auto's transfer box to a manual transfer box, and have asked a friend who breaks the odd Jimny whether he has an auto one, as this may prove ideal for The Boogie to give me a lower gears offroad...
Cheers Neil
- Thank you received: 923
10 Mar 2021 14:44 #233608
Replied by X8GGY on topic Re:Re:Re:Re:Transfer case info
Not sure whether the gears would be interchangeable Neil
Martin could probably provide part numbers if you ask him nicely...
If you asked him really nicely if you had a list of the gear part numbers in each box you could see if the rest of them were common / the same...
I myself will keep an eye on eBay just incase one pops up...
10 Mar 2021 15:29 #233612
by Old Neil
What's the call Sir Martin, the keeper of the knowledge
Replied by Old Neil on topic Re:Re:Re:Re:Re:Transfer case info
Yeah I'm thinking the same ,with the reduction gear set's they state you have specify one or the other parts aren't interchangeableX8GGY wrote: Not sure whether the gears would be interchangeable Neil
10 Mar 2021 16:23 #233617
Replied by mlines on topic Re:Re:Re:Re:Re:Transfer case info
The following parts change between the manual and automatic.
Part 8 - Chain
Part 7 - Input shaft
Part 10 - Output Gearset
Part 3 - Front Drive Clutch - lots of different thicknesses
Part 8 - Chain
10 Mar 2021 16:39 #233619
Replied by X8GGY on topic Re:Re:Re:Re:Re:Transfer case info
He's a good egg! Nice one Martin
10 Mar 2021 21:19 #233631
by Old Neil
Replied by Old Neil on topic Re:Re:Re:Re:Re:Re:Transfer case info
Thanks Martin
Neil
Neil
Time to create page: 0.135 seconds
