BigJimnyMeet 2024
Re:Re:2012 Jimny Gearbox
25 Feb 2021 18:05 #233264
by Stefan
2012 Jimny Gearbox was created by Stefan
Hi everyone. So I got another question for you guys.
My Jimny has a gear whine, whenever I drive, so this made me wonder whether the 2012 model perhaps had a gearbox with straight gears, as the are noisier than the modern gearboxes with bevell gears. Does it have straight gears? Or may there be a cause to this whine? I changed all the diff oils, except the gearbox ane transfer case as the transfer case had sufficient oil and gearbox was to hard to reach the plug and I don't know how I'll fill it back up in that stupidly small space.
Anyone that can help me please? Shed some light on the situation for me?
Thanks again,
Stefan
Thanks again,
Stefan
- Thank you received: 1761
25 Feb 2021 18:24 #233265
Replied by Lambert on topic 2012 Jimny Gearbox
Is there any particular gear that is noisy more than the others? As to replacing the gearbox oil with a little perseverance it's possible if messy to refill with the spout on one of the 1 litre bottles but it's definitely a faff.
- Roger Fairclough
- Thank you received: 194
25 Feb 2021 18:42 #233266
by Roger Fairclough
Replied by Roger Fairclough on topic 2012 Jimny Gearbox
To my knowledge, the only straight cut gears you will find are for reverse.
Roger
Roger
25 Feb 2021 18:58 #233268
by Busta
Replied by Busta on topic 2012 Jimny Gearbox
I'm not entirely sure when the last production car with straight cut gears was sold, but I'd wager it was about 60 years before 2012. Chances are your gearbox is failing as many around that age do. There is information about R72 gearbox failure in the Wiki.
- Thank you received: 552
25 Feb 2021 18:58 #233269
by Scimike
Replied by Scimike on topic 2012 Jimny Gearbox
I suspect nothing is wrong with it, they do have a more noticeable gear noise than a "normal car". Plenty of gears in motion below so is to be expected.
A work colleague got in mine and commented it sounded like straight cut gears, he's into performance "sleepers", so he should know!
It's actually very quiet, but I do understand his comments in the lower gears.
I quite like it - makes travel slow sound fast
- Roger Fairclough
25 Feb 2021 19:42 - 25 Feb 2021 19:42 #233270
by Roger Fairclough
Some early Ferrari g/boxes used grease as the lubricant. Maybe they had straight cut gears!
Roger
Roger
Last edit: 25 Feb 2021 19:42 by Roger Fairclough.
25 Feb 2021 19:57 - 25 Feb 2021 20:00 #233273
by Stefan
Replied by Stefan on topic 2012 Jimny Gearbox
Mostly noticable in 2nd and 3rd gear. Sounds noisier than reverse. I'll need a DIY oil pump, the spout won't even go in there.
Last edit: 25 Feb 2021 20:00 by Stefan.
25 Feb 2021 19:59 #233274
by Stefan
That is also what I know, but wasn't sure about the other gears, it's almost noisier than reverse.
25 Feb 2021 20:03 #233275
by Stefan
Well it almost sounds louder than reverse. I can enjoy it too at times. But I never heard a car like this so I became a bit concerned.
- Thank you received: 305
25 Feb 2021 22:29 #233278
by sniper
Replied by sniper on topic 2012 Jimny Gearbox
Service the drivetrain..... change oils in the gearbox, transfer box and diffs. If still noisy investigate further.....
sniper
sniper
- Thank you received: 36
25 Feb 2021 23:08 #233279
by Old Neil
Replied by Old Neil on topic Re:2012 Jimny Gearbox
What's the history of the jimny has previous owner put reduction gears in transfer case ,I've heard they are noisey?
26 Feb 2021 08:48 #233291
by Busta
Replied by Busta on topic Re:2012 Jimny Gearbox
They would be noisy in all gears, not just 2nd and 3rd.
Time to create page: 0.220 seconds
