BigJimnyMeet 2024
Re:Re:Re:Re:Front axle oil seal.
- Roger Fairclough
- Thank you received: 194
19 Feb 2021 11:30 #232988
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Front axle oil seal.
Whilst I think about it, would someone care to tell me how a king pin bearing can fall out when been re-assembled?
Roger
Roger
- Thank you received: 651
19 Feb 2021 12:53 #232991
Replied by jackonlyjack on topic Re:Front axle oil seal.
Nothing holding the bearing in place apart from grease
The hub slides on into place then it holds the bearings in
King pins slide through the hub into bearings
- Roger Fairclough
19 Feb 2021 14:21 #232993
by Roger Fairclough
From memory when I rebuilt my SJ 413 hubs the bottom king pin was assembled with the bearing in place on the pin. With the top bearing in place, you offered up the knuckle , bottom first until bottom bearing slides into position and then you push the top into position. At no time can the bottom bearing fall out.
Is this not possible with later marks?
Roger
Roger
- Thank you received: 1759
19 Feb 2021 18:09 #233004
Replied by Lambert on topic Re:Front axle oil seal.
There isn't enough clearance between the knuckle and the chalice.
19 Feb 2021 19:26 #233008
by Busta
Replied by Busta on topic Re:Front axle oil seal.
"Chalice"- good word!
Roger, access to the bolt heads isn't ideal. I could get a 1/4" drive socket on them with a short extension but not a 1/2". Next time I'll replace them with socket caps.
- Roger Fairclough
19 Feb 2021 19:45 #233009
by Roger Fairclough
No idea what a Chalice does on a Jimny.
Busta, how about a short 3/8" socket with a wobble drive extension?
Roger
Roger
- Johnniehec
- Thank you received: 56
19 Feb 2021 22:14 #233019
by Johnniehec
Replied by Johnniehec on topic Re:Front axle oil seal.
Busta re your video, I've learned something new tonight, I never knew the CV fitted through the hole in the swivel with the stub removed, probably because I've only ever been in there because the king pin bearings needed replacing. But why do you need to remove the freewheeling hub and the circlip? Thanks, John.
- RayPaterson
- Visitor
20 Feb 2021 11:05 #233037
by RayPaterson
Replied by RayPaterson on topic Re:Front axle oil seal.
That circlip is the worst part of the whole job. Does anyone know what size it is? I can't even find a consistent way to measure circlips.
Ray
Ray
20 Feb 2021 15:50 #233048
by Busta
I made that video to help people removing CVs. You need the circlip off to get the CV out of the hub, but it's also much easier to re-fit the driveshaft without having the whole hub on the end of it so I would reccomend it to anyone doing a similar job, especially if you've damaged seals while fitting the shafts in the past. Removing the hub and circlip should take no more than a minute but if for some reason you find it difficult then I'm sure it can be done with it still in place.
Ray, the circlip is reusable but you can get the size by measuring the diameter of the groove. I'll check it for you next time I'm near a CV...
The following user(s) said Thank You: Johnniehec, RayPaterson
20 Feb 2021 17:28 #233049
by Busta
It's a 25mm circlip.
The following user(s) said Thank You: rayz_x
21 Feb 2021 16:43 - 21 Feb 2021 16:44 #233074
by bryn
Replied by bryn on topic Re:Front axle oil seal.
I had a seal that would fail regularly and it turned out that the wheel baring was going. Might be worth checking that when you have it jacked up by grasping the wheel at the top and bottom and attempt to rock it.
There should be minimal movement. Excessive play may indicate a worn baring.
bryn
bryn
Last edit: 21 Feb 2021 16:44 by bryn.
- Roger Fairclough
21 Feb 2021 18:31 #233076
by Roger Fairclough
There are two possible sources of wheel movement, wheel bearings or king pins. If you find movement get someone to push hard on the foot brake. This will clamp the brake disc to the caliper and effectively eliminate wheel bearing wobble. If there is still movement at the tyre then it is king pin bearings. Note that it is possible to have both sets of bearings at fault at the same time. To eliminate just wheel bearing wear is easier if you have a stethoscope to hold against the end cover whilst you spin the wheel and listen for a rumbling. If both sets are perfect , there should be no movement at all when you rock the wheel.
Time to create page: 0.182 seconds
