BigJimnyMeet 2024
Vacuum Hub bolts
- Thank you received: 1755
06 Feb 2021 05:43 #232522
Replied by Lambert on topic Vacuum Hub bolts
Not directly related but the main bolts on avm ones are cap heads and as far as I am aware cap heads start at 10.6 so would be a suitable alternative. Certainly in the 90 thousand miles I have had them on Dreadnaught the only failure was internal and not related to either set of bolts.
- Thank you received: 923
06 Feb 2021 09:57 - 06 Feb 2021 10:01 #232523
Replied by X8GGY on topic Vacuum Hub bolts
I've got a few...
what's the best price you've had?... knock a penny off and donate that amount to this excellent forum, PM me your address and they'll be in the post straight away
Dave
Dave
Last edit: 06 Feb 2021 10:01 by X8GGY.
The following user(s) said Thank You: RayPaterson
06 Feb 2021 11:00 #232525
by Busta
Replied by Busta on topic Vacuum Hub bolts
A manual locking hub failure? Blasphemy!Lambert wrote: ... the only failure was internal and not related to either set of bolts.
06 Feb 2021 12:45 #232529
It did have over 70000 miles on it at the time. Part of one of the bearing surfaces delaminated and was making an appalling noise.
- Roger Fairclough
- Thank you received: 193
06 Feb 2021 13:15 #232534
by Roger Fairclough
Replied by Roger Fairclough on topic Vacuum Hub bolts
Big end bolts are usually rated at or above 12 and no manufacturer would use them if there was any chance of failure due to shear.
Roger
Roger
- Roger Fairclough
06 Feb 2021 13:19 #232536
by Roger Fairclough
From memory, the flanges, whether solid or manually engaged are located by 2 hardened steel pins which should remove any chance of shear?
Roger
Roger
06 Feb 2021 16:18 #232539
Maybe on a Toyota but not a Jimny.
- Roger Fairclough
06 Feb 2021 16:45 #232541
by Roger Fairclough
I was thinking more of an SJ413, but I did say it was from memory.
Roger
Roger
Time to create page: 0.131 seconds
