BigJimnyMeet 2024
Body lift
- Thank you received: 1755
- Roger Fairclough
- Thank you received: 193
29 Dec 2020 11:08 #231297
by Roger Fairclough
Replied by Roger Fairclough on topic Body lift
As a matter of interest, how do you remove the bolts?
Roger
Roger
- Roger Fairclough
29 Dec 2020 17:24 #231312
by Roger Fairclough
Another tool to try would be a nut splitter. Clean off all the corrosion. If necessary cut a slot in the large washer that supports the mounting rubber. This will allow you to get the splitter full onto the nut. There is usually no need to go full depth on the nut, just enough to spread it a little. Mole grips or a small pipe wrench will then remove the nut. You may be lucky and find the thread covered by the nut to be in good enough condition to re-use but once the body is off I would use an angle grinder to form a taper on the corroded threads. This will make re-assembly easier.
Roger
Roger
- Thank you received: 49
18 Feb 2021 21:16 #232972
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Well, today I managed to get my chassis nuts off. All 6 remaining nuts were heated and hydro-shocked. They span off the threads quite easily after that. Looks like I will be able to use the same threads to reassemble the body again, which saves me a load of hassle. Hope to get the body split tomorrow and get some of the body repairs done at the weekend. Fingers crossed that the chassis is in good nick after the rust is needle-gunned off.
- Thank you received: 923
19 Feb 2021 08:29 #232983
Good News Mike!
19 Feb 2021 20:12 #233010
by Mike G
Just some pics of the separation. Lots of work to be done on the body, but the chassis looks not too bad so I think the needle gun will be required tomorrow.
19 Feb 2021 20:50 #233014
by Mike G
I did picture how it would look lifted up that high. At least it would be easier to maintain
Think I'll just stick with my modest two inches though. I've enough work to do without getting any mad ideas....
Time to create page: 0.141 seconds
