BigJimnyMeet 2024
rear diff noise
26 Nov 2020 15:20 #230419
by mag
rear diff noise was created by mag
Help please from all you techy folks ( which isn`t me!!! )
Whine from car over about 25mph , think prob rear diff , jacked up back end and if you spin either back wheel by hand , you can hear a clicking noise as wheel goes round , sounds like coming from wheel but it`s both sides whichever way you rotate wheel , start it up and engage 1st , can`t really hear anything , get up to 3rd / 4th , 30mph upwards and a noise starts which is louder when you decelerate , prob rear diff or could it be noisy transfer box , any simple ways to diagnose ?? car drives fine in 2wd , 4wd and low , just whines at 25mph + , any help appreciated PS. 53 plate jimny 95k on it
- Thank you received: 1761
26 Nov 2020 17:25 #230421
Replied by Lambert on topic rear diff noise
Is this a new noise? Would it be possible for you to upload a recording of the noise to the Internet? A Jimny is quite a loud vehicle under the best of circumstances so it could be normal?
26 Nov 2020 20:14 #230422
by mag
Replied by mag on topic rear diff noise
few months , changed diff oil in may / june , getting louder i think
- Thank you received: 653
26 Nov 2020 23:28 #230426
Replied by jackonlyjack on topic rear diff noise
clicking noise will be abs tick tick tick gets faster the more you spin a wheel
The following user(s) said Thank You: mag
27 Nov 2020 09:00 #230430
by mag
Thanks , don`t remember hearing it before but prob more tuned into noises now i think rear diff is noisy , thanks again
27 Nov 2020 09:03 #230431
Replied by mlines on topic rear diff noise
Mine did that when a crown wheel bolt came loose and eventually fell out taking the teeth with it.
27 Nov 2020 12:35 #230435
Oil is cheap. Change it again and examine it for any metal debris or glinting. If its clean then whilst not definate it a good indicator of reasonable condition.
- Thank you received: 552
28 Nov 2020 10:14 #230453
by Scimike
Replied by Scimike on topic rear diff noise
Did you change the diff oil originally because of the noise or has the noise appeared since the oil change?
Just try to establish the time line.
Sorry to ask this but you did use the correct oil grade?
Just covering everything.
Mike
Mike
28 Nov 2020 11:04 #230454
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic rear diff noise
I thought I had diff issues, actually turned out to be the rear bearings.
28 Nov 2020 18:58 #230472
by mag
changed oil in diff as i thought it sounded noisy , since then , appears to be getting louder but still wonder it is rear wheel bearings !!
don`t want to chuck a diff in it and find noise is still there , likewise as rear bearings ( with abs ring ) is £70+ a side , don`t want to just to change them either , bloody cars !!!
28 Nov 2020 19:00 #230473
by mag
how did you discover it was bearings not diff ???
29 Nov 2020 00:44 #230484
by Scimike
If the wheel bearings are not showing any signs of problems, eg movement or rough feeling when rotated then the only option is to go old school.
You need one of these and have a listen to each side as you turn the wheels.
Mechanics stethoscope.
Very effective at locating the source of those strange noises. If your bearings are ok I would expect both sides to sound much the same, one side louder than the other it's likely the loud one is on the way out. If you hear a rumble on both sides have a listen to the diff area to see if it's the source. Not much money, about £6.50 on Amazon, a worthy item in the tool box even if it's no help this time.
Time to create page: 0.154 seconds
