BigJimnyMeet 2024
Re:Re:Re:Lift kit & suspension for the JB74
- Thank you received: 34
28 Jul 2020 11:27 #225778
by crash486
Replied by crash486 on topic Re:Re:Re:Lift kit & suspension for the JB74
According to someone far more knowledgeable than I "gwagansteve" had the following to say
"On a car with radius arm suspension, the roll centre is approximately 1/2 way along the panhard rod. Raising the axle end will raise the roll centre by about 1/2 the amount the axle end was raised. The higher the roll centre, the more the body of the car is trying to push against the force acting on it in order to body roll. This kit will help to reduce the body roll people complain of with OME suspension because OME don’t add unwanted shock valving to compensate for the increased height (other manufacturers use the term “heavy duty” to cover the fact ride harshness increases with suspension lift- it shouldn't.) Additionally, the flatter angle will reduce perceived sway and lateral body movement."
crash486 JB74W
crash486 JB74W
The following user(s) said Thank You: Boris Ekner
- Boris Ekner
- Thank you received: 1
28 Jul 2020 19:17 #225801
by Boris Ekner
Replied by Boris Ekner on topic Re:Re:Re:Lift kit & suspension for the JB74
The answers given here are very interesting & educational to read. Thank you all!
- That said I would like to hear Martin Lines opinion & experience regarding choice of lift-kit.
Does anyone know how to tag him to this thread?
Regards
..Boris
Regards
..Boris
28 Jul 2020 19:52 - 28 Jul 2020 19:53 #225806
Replied by mlines on topic Re:Re:Re:Lift kit & suspension for the JB74
Every lift kit is different. Quite a few are just "whatever is on the shelf and fits" so are not specifically designed for the Jimny, these can give a poor ride.
Some "50mm" lift kits just add "50mm" to the spring length, typically these lift more that 50mm. Others alter the number of coils and wire diameter so are a more engineered solution.
The problem with the Gen4 is that there is a chassis crossmember in the way of the propshaft. Therefore kits some kits which are advertised as 50mm but are in fact slightly higher need a drop bracket to stop the prop hitting. Other kits which are advertised as 50mm but are slightly lower (48mm for example in the Trailmaster variant) do not need it.
Panhard rod effective length is affected by a lift, but 50mm lift is small enough not to need panhard rod correction or indeed castor correction. The technical bit about roll centre will affect it with larger lifts but with 50mm you would be hard pressed to tell. The wheels are still basically central on the line of the car and not offset to one side.
I would simply look at the ride reports and see which ride suites your need at 50mm lift. Trailmaster is very road friendly in my opinion. I have heard that others are more firm on the road and indeed the Jimny Style one seems to be positively rigid.
So at this height, ask around about the ride and go with your heart.
Last edit: 28 Jul 2020 19:53 by mlines.
- Boris Ekner
29 Jul 2020 22:42 #225841
by Boris Ekner
Thanks, Martin. Your input is greatly appreciated.
Regards
..Boris
Regards
..Boris
Time to create page: 0.091 seconds
