BigJimnyMeet 2024
Re:Re:Drop link removal?
- Thank you received: 651
14 Jul 2020 16:57 #225080
Replied by jackonlyjack on topic Re:Drop link removal?
Only ever owned 2 one got cut up other is outside
Maybe where the only two in the UK with this axle
The following user(s) said Thank You: HUN
14 Jul 2020 17:45 #225083
Replied by mlines on topic Re:Re:Drop link removal?
Perhaps it's just the picture but the steel in yours looks much thicker than mine, that's what made me think it had been repaired.
In fact mine is thin enough to be bent inwards making the space small, if I had a arb I would have to bend it out to fit.
- Thank you received: 1759
14 Jul 2020 17:54 - 14 Jul 2020 17:54 #225084
Replied by Lambert on topic Re:Re:Drop link removal?
This is mine with the drop link. The axle is of indeterminate age and origin but from an automatic. Your drop link looks much bigger than mine.
Last edit: 14 Jul 2020 17:54 by Lambert.
- Thank you received: 551
14 Jul 2020 18:13 - 14 Jul 2020 20:06 #225086
by Scimike
It must have gone in at the factory!
Actually looking at the lock nut the amount of thread sticking above the nut on mine is similar to the the amount of thread on yours, BUT only after you have chopped yours down, suggesting it was too long?
Still does not explain how it was assembled.
Replied by Scimike on topic Re:Re:Drop link removal?
Last edit: 14 Jul 2020 20:06 by Scimike. Reason: Thread about the same now after mods
- Thank you received: 45
14 Jul 2020 20:47 - 14 Jul 2020 20:48 #225100
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic Re:Re:Drop link removal?
Thank you for your enthusiastic photos Gents, looks like I've accidently started a competition!
Scimike, well spotted! The back is slightly domed which makes it even more impossible to get out.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 14 Jul 2020 20:48 by HUN.
15 Jul 2020 16:21 #225127
Replied by Riccy on topic Re:Re:Drop link removal?
Fitted using Clarkson method methinks (hammer)
The metal it goes into can be bent back and forth a little to allow some space.
Or maybe it was installed in bits, or at a specific rotation angle thats been lost with age or filled with grease
Glad its sorted out though
Time to create page: 0.156 seconds
