Fitting a rock lobster (SJ) transfer box in a Jimny...
Probablynotfrank wrote:
I'd be interested in the measurements of the shortened R72 shaft?Riccy wrote: Ive got a shortened intermediary prop for an R72 gearbox to your welcome to, but it will have the wrong spline count on the gearbox end of it. Might be possible to swap over the UJs to get it right
My R72 shaft next to an SJ wish I knew about the different splines first
I'll swap you my shortened R72 shaft for your decent looking SJ one if you fancy a 0 cost swap? (assuming UK postage costs similar to each other), send me a PM
I can measure it on friday when next in the garage otherwise...
- Thank you received: 923
Looking back at old photos again...
I can't help but think...
That the bucket / cradle mount almost wants to follow the same lines as the transfer box spine outer edge? ...
- Thank you received: 1755
- Thank you received: 225
Lambert wrote: Regarding the spine, does not integrating the spine with the impact protection create a situation where the transfer case becomes a stress member and is at greater risk than if you were to have it isolated from the protection?
Yes
zukebob wrote: Yes
A good comprehensive and well reasoned answer Zukebob!
I’m thinking brackets linked to the spine (which protects the transfer box from stresses) and a skid plate under it but not integral to it then?
- Thank you received: 329
Some cars got 200hp volvo turbo engine, and 35" tyres and toyota axles.
Very few has had torque related problems as far as I know. The cars get bashed and crushed of course until something breaks and it all does, but still the 4.16:1 case remain in use for many.
